Metal Box Clamps Wont Hold Down Nm - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 09:44 AM   #1
macon, ga bibb county
Rewards Points: 150
Metal box clamps wont hold down nm
Hey guys I'm wiring an outlet under my house for a sump pump and needed a junction box for some slack so I bought a metal box with the clamps already in it but when I tighten it down all the way I can still pull out the 12awg nm. Isn't that what the clamps are for? They won't hold it in.
Lupus71 is offline   Reply With Quote
Old 07-06-2013, 10:18 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Pics?
Old 07-06-2013, 10:36 AM   #3
Electrical Contractor
kbsparky's Avatar
If you have a metal box with "X" clamps in it, you are using the wrong type of box, or the wrong wiring method.
As Speedy pointed out, a nice close-up picture would be in order here.
However, if you properly fasten the nm cable within 12" of the box, then it's highly unlikely the wire will pull out on its own in any case ....
-KB
Old 07-06-2013, 11:42 AM   #4
Rewards Points: 150
Also I just bout this box and cover and I couldn't find a box with four screw holes for the cover. Will this box and cover pass inspection? Thanks!
Old 07-06-2013, 11:57 AM   #5
What I do with those clamps is tighten them down all the way before putting the cable in. Then loosen it and put the cable in and snug down. NOT too tight though.
You only use two holes with those covers. They have four holes so you can rotate them 90 deg if need be.
metal sheathing DiegoJames Electrical 2 07-01-2013 07:59 AM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
TV Mount on Metal Studs - What hardware is necessary? theproman23 Home Theater 6 03-02-2011 05:28 PM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
Problen with hanging heavy draperies in sheetrock metal studs wall. Fixitgeorge Remodeling 1 04-11-2009 02:03 PM
