Messy Electrical, NOT DIY - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 01:35 PM   #16
Originally Posted by InPhase277 View Post
I like QO. It is a solid breaker, and its "snap" to the bus is very reassuring. I have seen far fewer failures from a properly installed QO panelboard than the other brands. Nothing against other brands, 'cause I like Siemens/ITE too, but if it's in the budget, I get QO.
It always has a nice 'snap' to the board. The breakers are very sensitive as well.
rgsgww is offline   Reply With Quote
Old 01-18-2009, 02:03 PM   #17
Electrician
Originally Posted by rgsgww View Post
I think the inspector was smoking something...I can't believe he passed this crap!
I only saw a couple violations, anyone else want to share? You generally get what you pay for, making artwork out of a panel is usually not in the budget.
chris75 is offline   Reply With Quote
Old 01-18-2009, 02:08 PM   #18
Maybe I should have taken pictures of other things I quickly fixed, One room had all exposed j-boxes, another room had bx entering a plastic box with a ground wire wrapped around it, in my crawl space a whirlpool tub 20 amp outlet was tapped off with 14 awg.
I do see some violations, but am curious as to what you found?
Old 01-18-2009, 03:49 PM   #19
Rewards Points: 266
I agree. What you have there is what is typical in most old houses. It isn't pretty, but is there anything major wrong? Even if you have a service professionally replaced doesn't mean that they are going to go over the whole system with a fine toothed comb.
junkcollector is offline   Reply With Quote
Old 01-18-2009, 03:51 PM   #20
Ive fixed alot of the major wrong.
I suppose I will just clean up some of the wiring.
Old 01-18-2009, 06:44 PM   #21
Well...while pulling out 2 abandoned bx cables, 12/3 romex and about 30 ft of 6 awg ground wire I came upon one of many of these
Now I have more work to do!
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
