Old 01-18-2009, 01:15 AM   #1
Messy electrical, NOT DIY
I just felt like posting some pictures of messy electrical in my house.
The panels (2x200) QO
Aren't tvss supposed to be short and straight as possible.
Where do I run the wires? Oh, I should use the unused mounting holes!
What is a bx connector? Damn...they aren't in my truck. These should work fine.
Oops...the ground slipped out of my hands!
Your wayyy to generous
I don't even want to tackle this!
Ugh...I don't even have plastic bushings...
rgsgww is offline   Reply With Quote
Old 01-18-2009, 01:25 AM   #2
Electrician
ctsmiths's Avatar
Hey at least you have square D and not GE.
ctsmiths is offline   Reply With Quote
Old 01-18-2009, 01:28 AM   #3
Yep, Those breakers are nice.
Old 01-18-2009, 01:50 AM   #4
My License Ain't 4 Sale..
Yep... which one do you flip to clean all that up?
Old 01-18-2009, 01:52 AM   #5
That always makes me drool! I remember that work. Such nice work.
GE is nice.
Old 01-18-2009, 01:53 AM   #6
Are you sure those aren't BX connectors? There is a kind that looks exactly like a romex connector except it has a bottom that the BX stops against.
Old 01-18-2009, 01:57 AM   #7
I will have to check again...but I am almost sure that they are romex connectors.
I just cleaned up a j-box in my basement to an ac compressor.
The "electricians" couldn't fit a 3/4" bx into a 3/8" bx set screw connector so they diddn't put it in there.=
Old 01-18-2009, 06:53 AM   #8
the Musigician
DangerMouse's Avatar
that ALMOST looks like what i had to fix before we could move in here!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-18-2009, 09:04 AM   #9
Electrician
Just curious, why do people think SQ. D is better?
chris75 is offline   Reply With Quote
Old 01-18-2009, 09:41 AM   #10
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Because the Square D distributor is closer to the shop and they have doughnuts and coffee every morning and free lunch on Tues & Thurs
wirenut1110 is offline   Reply With Quote
Old 01-18-2009, 09:52 AM   #11
I like QO. It is a solid breaker, and its "snap" to the bus is very reassuring. I have seen far fewer failures from a properly installed QO panelboard than the other brands. Nothing against other brands, 'cause I like Siemens/ITE too, but if it's in the budget, I get QO.
Old 01-18-2009, 09:58 AM   #12
When do you want me over to make it right?
bobelectric is online now   Reply With Quote
Old 01-18-2009, 01:21 PM   #13
Idiot Emeritus
Square D is the only manufacturer that I know of that allows (legally) two wires under a breaker lug. 10-30 amp is listed for one or two #14, #12, or #10.
Rob
micromind is offline   Reply With Quote
Old 01-18-2009, 01:31 PM   #14
Its true!
Old 01-18-2009, 01:33 PM   #15
I think the inspector was smoking something...I can't believe he passed this crap!
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
