Mess Saver Doing Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 06:54 AM   #1
Rewards Points: 270
Mess saver doing recessed lighting
I have seen this thing on This Old House which is like a boot you put on your drill that collects all the dust when drilling holes. Is this something i should find easily at the home center or is it a specialty tool?
If not, any other suggestions for not making a huge disaster? I believe I will be using a hole saw.
pcampbell is offline   Reply With Quote
Old 11-26-2010, 09:47 AM   #2
Just call me Andrew
Rewards Points: 1,020
this is more a building & construction question...but you could have a helper (or do it yourself) hold a shop vac right near the area to suck up all the dust.
Andrew
secutanudu is offline   Reply With Quote
Old 11-26-2010, 12:07 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
I have seen those at HD and Lowes.
Old 11-26-2010, 12:58 PM   #4
Electrical Supplier
Rewards Points: 150
Take an old basketball, cut in half or so, put a minimal cut in it, place it between the hole saw arbor and the chuck. Make sure the basketball spins freely (as to not put scuffs on the ceiling, you also might put some cloth tape/medical tape on the edges to prevent this further)
Boo yah, cheap dust shield. While not transparent it works. If you want transparent, try maybe a plastic pie cover or something like that.....
LyonsElecSupply is offline   Reply With Quote
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 06:03 AM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
