Old 06-08-2009, 03:23 PM   #16
300zx's Avatar
Post
Melted Wires - Crisp marks on other
A megger is often a colloquial term for a circuit tester which puts a very high voltage at a very low current across two conductors to make sure that they are properly insulated.
300zx is offline   Reply With Quote
Old 06-08-2009, 03:55 PM   #17
Originally Posted by ScottR View Post
I'm concerned that the cable that overheated was in contact with another cable somewhere else in your walls and burnt off its jacket/insulation.
Maybe I'm being overly paranoid..
The wires exit the wall in the garage attic and run for about 20 feet before going into the core house wall and to their final termination points.
The only signs of heat is immediately above the panel. The wires all look fine in the garage attic.
Thanks all.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-08-2009, 05:43 PM   #18
300zx's Avatar
Post
I don't think think you have anything to worry about.But if you do call electrician to megg out wire will detect any faults in wire.
Confusing Chandelier Wires Burnsy Electrical 21 02-22-2009 04:29 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
