Melted Wall Recepticle - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 07:43 PM   #16
Learning by Doing
Leah Frances's Avatar
Originally Posted by kbsparky
You have a bad connection(s) in that outlet. IT could be the outlet itself, OR the molded plug on the A/C unit. ... or both.
Sometimes, you will have to change =both= to remedy the problem.
Sparks brings up a good point. Do take a close look at the cord and plug.
You don't know what the former resident was doing. Maybe they only turned on the AC when the other stuff was off.
There IS a problem that needs to be uncovered.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-18-2011, 07:49 PM   #17
Electrical Contractor
kbsparky's Avatar
I have found that once an a/c cord has started to melt, along with the receptacle outlet, both have to be replaced, or else you will just melt your replacement outlet as well.
-KB
Old 06-18-2011, 10:02 PM   #18
jschaben
Rewards Points: 502
My money says it's a stab-in outlet.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-19-2011, 04:54 AM   #19
dmxtothemax's Avatar
Rewards Points: 5,600
Too much draw on the rest of the circuit would not cause
the outlet to melt.
Only problems with the ac units receptical.
Replace both the outlet and the plug on the ac unit,
Use the best quality you can find.
This may cost a little more in the short term,
But in the long term you will have a reliable unit.
Dont use back stab.
dmxtothemax is offline   Reply With Quote
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
