Measuring Load At A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 04:18 PM   #1
Measuring Load at a panel
Can you install a device (ampmeter?) permenantly to a panel to read the load?
Im particulary thinking of the situation with a generator and interloc kit.
I'd like to know just how many circuits I can use.
Would I need a seperate meter on each leg?
This is new construction...
Thanks...Paul
pshadwick is offline   Reply With Quote
Old 12-14-2011, 06:14 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Yes you can....they are called current taps....come in different flavors....
One of the big issues you have decide is how you intend to measure the output....typically 1-5Vdc or 4-20ma.....if this then causes you to ask more questions....then you are most likely treading into area's over you head....
Not that it can't be solved if you do your research...but, there are also some home monitoring systems you can get...but are pricey.....do a search on home power monitoring....I don't know the link off hand, but I recall one product that you can install that monitors your real time power usage and comes with a display that you keep in your house....
Old 12-14-2011, 06:27 PM   #3
Master Electrician
Rewards Points: 3,920
To me they are known as current transformers or CT's for short.
brric is offline   Reply With Quote
Old 12-15-2011, 09:13 AM   #4
Thanks for the information, and yes it sounds like I'd be in over my head.
I was hoping for a simple soultion like 1 or 2 ampmeter like guages. When switched to the Generator I'd just turn on circuits until the guages maxed out at the generator capacity.
Probably more trouble than it would really be worth.
Thanks Again...Paul
Old 12-15-2011, 08:22 PM   #5
Rewards Points: 64
Do a google search for Gentran and look at what they have to offer.
JACK HOTTEL is online now   Reply With Quote
Critique my Sub Panel rjniles Electrical 18 05-17-2011 11:31 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
100A Fuse Panel Replacement Charlie1101 Electrical 4 07-25-2009 02:22 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
