Measuring 240v, 4 Wire Curcuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 01:39 PM   #1
Measuring 240v, 4 wire curcuit?
Can I measure 240v on my meter? I can only get 120v, however, I do get 120 from each hot wire. I'm thinking this is right?
jclee is offline   Reply With Quote
Old 03-08-2013, 01:44 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
If you are measuring 120 from each hot to ground or neutral, but not 240 across the 2 hots, you have a problem.
The circuit is wired wrong or one leg is open and you are measing one side back thru the load.
Coastal South Carolina
Old 03-08-2013, 01:49 PM   #3
I'm getting 120v from black to ground/neural and 120v from red to ground/neutral
I have not measured between black and red. I didn't think you could measure 2 hots together
Old 03-08-2013, 01:59 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
THAT is your 240V.
Speedy Petey is online now   Reply With Quote
Old 03-08-2013, 05:15 PM   #5
A "Handy Husband"
rjniles's Avatar
As Speedy says, that is the only way you will measure 240.
Old 03-08-2013, 05:17 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,102
If both phases originate from the one hot line,
then you will measure nothing or close to it !
But if they come from different hot lines,
then you will measure 220 - 240v.
So yes you can measure across two hot lines !
Be very carefull, the mother of all bites awaits the unwary !
Death shortly after.
*CAUTION*
dmxtothemax is offline   Reply With Quote
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 02:05 AM
240v questions.... ITSANSS Electrical 16 05-11-2011 06:40 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
