Measure Current To Refrigerator - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 09:15 AM   #1
measure current to refrigerator
I'm trying to measure the current required by my refrigerator. I bought a 10 watt 0.1 ohm resistor and spliced it into one of the wires (not the ground wire) in a short 14 ga. extension cable to the refrigerator. I'm guessing that the refrig requires about 8 amps, so the voltage cross the 0.1 resistor should be about 1 volt. But when I try to measure it, my voltmeter doesn't register anything (and the refrigerator is indeed powered by the extension cord). What am I doing wrong? Or is there a better way to meaure the current (besides buying an expensive AC current measure gauge)?
tfox37380 is offline   Reply With Quote
Old 07-20-2012, 09:18 AM   #2
Licensed electrician
Rewards Points: 1,758
The refrigerator data plate will have the information on it. Look near a door for a sticker.
Old 07-20-2012, 09:30 AM   #3
Rewards Points: 826
get one of these. They are cheap and much more accurate than you will get the way you're going about it. Sold at many big box stores and online.
http://www.p3international.com/produ.../p4400-ce.html
curiousB is online now   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
COLDIRON (07-20-2012)
Old 07-20-2012, 09:50 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
You are thinking like an engineer, that's what.
You need to start thinking like a normal person.
Yeah, a $20 Kill-A-Watt like in the link.
http://www.amazon.com/P3-Internation.../dp/B00009MDBU
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (07-20-2012)
Old 07-20-2012, 10:25 AM   #5
Master Electrician
By the time you got a resistor the right size to actually impact the circuit enough. to actually measure the voltage you most likely would accomplish three things.
1. You may drop enough volts to mess up your fridge
2. The current readings won't be right anyways because you've change the resistance of the circuit.
3. Your resistor is going to end up popping unless its the size of a box of baking soda to handle all the wattage. Infact your lucky it didn't already as I doubt the leads are large enough to handle 8amps.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
Speedy Petey (07-20-2012)
Old 07-20-2012, 11:09 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Some of the questions on here make me gasp at times.
Old 07-20-2012, 11:17 AM   #7
I think your calcs and assumptions are fine, even with a tricky load like a compressor.
Try different things to get clues or have a fresh pair of eyes look at it. The real learning takes place when things don't work as planned.
Keep the resistor in the neutral lead and not the hot lead.
A 100W, 100 ohm, resistor also comes in handy for household elec. troubleshooting (a guy at a hamfest gave me one for free), as does a hair dryer.
Knowing the basics
= less unnecessary purchases = more self-reliance = some slightly increased risk in return for more knowledge = possible fear/contempt/rage/ridicule from others.
Old 07-20-2012, 06:02 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,494
Your meter is faulty !
Or you use the wrong input / setting.
It is dangerous !
Be really careful !
dmxtothemax is online now   Reply With Quote
Old 07-20-2012, 06:51 PM   #9
Master Electrician
I'm glad I'm not the only one sitting here thinking he's running 8amps through a 50 cent resistor lol. There's a reason they invented the clamp on meter
Old 07-20-2012, 06:56 PM   #10
E2 Electrician
I generally just use the nameplate on the appliance, guess that's way to easy of an idea....
Old 07-20-2012, 08:05 PM   #11
Missouri Bound's Avatar
What I have done to measure total appliance load is to buy a flat 3 wire heavy duty extension cord and split the hot lead from the rest of the cord. It makes it simple and easy to clamp an ammeter on the hot lead. Very simple and you don't need to take anything apart or "Rube Goldberg" something which may be dangerous.
Do you want it your way or the right way?
Old 07-20-2012, 08:43 PM   #12
Master Electrician
Lol ya seems to be. Although I've found fridges alway draw less than plate amperage. Unless you have the old style with the super chrome handles that lock in place and freeze your beer.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Can someone tell me why my low voltage lights are reading high current at the switch? kmc Electrical 5 06-04-2012 09:38 PM
Resistor/Led and Basic Electricity Questions Khivar Electrical 19 04-16-2012 06:15 PM
refrigerator in garage power bodekms Electrical 7 06-14-2011 07:59 PM
kenmore top freezer refrigerator problem. joanneh105 Appliances 3 06-13-2011 08:08 AM
