Meaning Of Recessed Lights That Are "Not Rated For Insulation"? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 09:31 PM   #1
Meaning of Recessed Lights That Are "Not Rated for Insulation"?
Hi all.
I'm thinking about buying a new condo (yet to be built), and I had an electrical question, so the builder suggested that I pass along the question to the electrical company that handles electrical installation for their new construction projects. My question was this. In areas in the house where recessed lighting is installed, the builder typically uses the traditional 5" or 6" recessed fixtures, the type that use a standard incandescent flood lamp. I inquired as to whether it would be possible to have 3" or 4" gimbal-mount recessed lights installed instead of the traditional fixtures (like these sold by Lowe's). Personally, I think these smaller fixtures are much more aesthetically pleasing than the run-of-the-mill recessed fixtures, and as they're relatively inexpensive, I wanted to look into the possibility of having the smaller fixtures installed from the get-go instead of going through the headache of trying to retrofit the 5" fixture holes to accommodate the 3" fixtures down the road.
I received an email the other day from someone at the electrical company stating that the lights I inquired about (I sent them the same link to the lights sold by Lowe's) were "not rated for insulation" and therefore could not be used. Could someone please explain what "not rated for insulation" means in terms of these recessed lights, and what would qualify a recessed ceiling fixture to be rated for insulation? I'm sure that the type of lights I need in this style that I want must be out there somewhere, but I don't know exactly what to look for or where to look.
Thanks!
DoItY is offline   Reply With Quote
Old 06-29-2012, 09:42 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Besides not being rated for contact with insulation...they are junk. When it comes to this kind of stuff, you can go by the saying, "You get what you pay for."
Now on to your question...
Some cans are rated to be in direct contact with insulation...they usually have an IC somewhere in the model number. Cans that are not IC rated have to be kept a certain distance away from insulation...IIRC its like 6".
Old 06-29-2012, 09:43 PM   #3
Licensed electrician
Rewards Points: 1,478
Recessed housing are either rated IC or non-IC. IC means the housing can be in contact with thermal insulation. Non-IC needs 3" of clearance all around the fixture from any insulation. This will leave holes for hot or cold air to create a constant drain on your HVAC system and permantly increase your energy bill. There are housing that can be installed over a non-IC to block some of this drain.
Your area may also require the use of AT or air-tight housings.
Old 06-29-2012, 09:44 PM   #4
Missouri Bound's Avatar
I think that the electrician is telling you that the fixtures originally intended are "rated" to allow insulation to be placed over and around them....and the ones you want are not.....I think. There are ways around that, but it will not doubt cost you extra to have it accomplished. Many (if not all) fixtures rated for insulation contact have a small thermal switch installed in the fixture which will cut the power in the event of overheating.
Do you want it your way or the right way?
Old 06-29-2012, 09:56 PM   #5
That said, are there any manufacturers of IC-rated 3" gimbal-mount lights that you would recommend?
Old 06-29-2012, 10:51 PM   #6
Master Electrician
Rewards Points: 3,818
Halo H38ICAT. They are not gimbal mount but they will use an adjustable gimbal trim, which is what I think you mean by "gimbal mount".
brric is online now   Reply With Quote
Old 06-29-2012, 11:31 PM   #7
k_buz's Avatar
Here's the thing...I'm not trying to dissuade you, but if a customer was asking my opinion on this situation, I would tell them that they are wasting their money on the gimbal ring trims. I use or recommend them in two situations.
The first being accent lighting...highlighting a picture or sculpture for example. The second reason I would use them is on a sloped ceiling to adjust for the angle.
With that said, if you are downsizing the cans from 6" down to 4" you are going to need more of the cans to produce the same amount of light. Your ceiling may look like swiss cheese if you are using these cans as your main lighting source.
Old 06-30-2012, 12:00 AM   #8
Busy DIYer
picflight's Avatar
Rewards Points: 150
Not rated for insulation means it cannot come in contact with insulation.
picflight is offline   Reply With Quote
Multiple recessed lights on two 3-way switches YellowBelly Electrical 6 11-27-2011 02:59 PM
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Commercial Electric vs. Halo recessed lights bubbler Electrical 0 10-12-2011 07:06 PM
IC recessed lights getting hot? shockingsi Electrical 4 08-04-2011 12:56 AM
