MC W/ground Loading From BX W/o Ground - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2012, 03:58 PM   #16
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The purpose of the ground is to protect the person if a wire should come loose in the appliance. Without ground YOU would become the closest thing to ground. With the GFCI and no ground wire if a wire should come loose and touch the appliance it will detect the change in voltage and trip the outlet.
sublime2 is offline   Reply With Quote
Old 04-03-2012, 04:04 PM   #17
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by amakarevic
there will be none, all are lights on the extending branch
The issue would be that if a wire cap came loose in the box and touched that fixture you could be shocked if you touched it.
How often would that happen or how often someone would touch that/those fixtures.......
Who's to say.
Old 04-03-2012, 04:07 PM   #18
Just a DIY guy
Originally Posted by sublime2 View Post
The BX would serve as ground only if the first box it ran from was in fact grounded to the panel. That does not appear to be the case here.
The missing connection could be anywhere. He might have a plastic box put in by a previous owner, or any number of broken/bad connections.
In my non-expert opinion, I'd say he is no worse off now than when his BX was ungrounded and feeding other lights. Not ideal, to be sure.
Is there a way to test for ground in jb's along the circuit? Like using a neon tester with one lead on the hot and the other on the box? If so, he could at least try to isolate the bad ground connection and maybe fix it.
M3 Pete is offline   Reply With Quote
Old 04-03-2012, 04:10 PM   #19
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
well fine but what would you do to make things right? there are a lot of people on this forum who are like code or theoretical nazis with next to no connection to what is practical or possible or feasible.
if you had 10 ft to redo between two lights at the end of a 150 ft long 2-wire BX circuit at the end of a house, would you tear all the walls to "do it right" or would you find a workaround?
jeez
Absolutely correct! It would be the work around for 90 % of the people doing it.
Old 04-03-2012, 04:15 PM   #20
Ravenworks's Avatar
The point that I was making was,the issue with using three prong outlets -VS- two.
Ravenworks is offline   Reply With Quote
Old 04-03-2012, 04:19 PM   #21
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
It appears we both thought he was talking about outlets.......
I hate that hind sight is always 20/20!lol
Old 04-03-2012, 04:26 PM   #22
Rewards Points: 1,062
i said:
a terminal section of one of my circuits that is used entirely for lights loads off of an old BX cable that has no ground and aluminum wires coated in cloth insulation (old). i used MC cable with ground. in the JB, i just put a green ground screw and pigtail the loading ground wire to it.
when testing the circuit extension, i temporarily installed an outlet so i can test it using a little Sperry plug-in indicator with 3 lights.
Old 04-03-2012, 04:28 PM   #23
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
when testing the circuit extension, i temporarily installed an outlet so i can test it using a little Sperry plug-in indicator with 3 lights.3
Slow deep breaths amakarevic..........
Old 04-03-2012, 08:44 PM   #24
Ravenworks's Avatar
What I am trying to say is this, you are using a new wire that does not have the ground hooked up you will NOT be able to use three prong outlets unless they are GFI outlets and even then you will have to label them as NOT having equipment ground.
If it were me I would put a note in each box stating what you did for future reference,because people forget and people move.As for the JB is it going to be accessable once you are done?
Old 04-03-2012, 08:52 PM   #25
all JBs **ALWAYS** must be accessible, always. they can't be behind sheetrock. even though i've seen it done
Old 04-03-2012, 08:55 PM   #26
dude, the outlet i installed for testing worked fine and it was not a GFCI
Old 04-03-2012, 09:27 PM   #27
Why the hell is everyone talking about GFCI and 3-prong
The man said it is on a circuit that ONLY feeds LIGHTING,Jeez!
Amazingglazier is offline   Reply With Quote
Old 04-03-2012, 09:33 PM   #28
I would do it in a heartbeat for lighting only
Originally Posted by amakarevic View Post
the most important question, again, is not whether the new setup is the way it should be in the perfect lala-land but more whether it introduces any defect compared to how it was before (2-wire BX all the way)
Go for it , it will be the same as it was till you can rip it out to the panel.
This is the real world.
The Following User Says Thank You to Amazingglazier For This Useful Post:
amakarevic (04-03-2012)
Tags
open ground receptacle
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
