MC Vs AC And Romex Quick Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 07:06 PM   #1
Rewards Points: 160
MC vs AC and romex quick question
i have metal boxes in my house from 1971 with 14-2 AC. i have added 14-2 romex to the switches and everything is grounded. can i use MC to add a feed to a new metal box that i had to install for a switch or should i just go buy AC? thanks
jhack836 is offline   Reply With Quote
Old 01-30-2013, 07:12 PM   #2
Master Electrician
Rewards Points: 3,964
MC cable has a green, insulated equipment grounding conductor within the jacket. Use the MC.
brric is offline   Reply With Quote
Old 01-30-2013, 09:09 PM   #3
Rewards Points: 160
ok so ac and mc are pretty much the same except mc actually has a grounding wire in it instead of the bare wire that you wrap around or clamp to the armor?
Old 01-30-2013, 09:25 PM   #4
Master Electrician
Yes. The armor is the grounding means with AC. The internal conductor in MC is the grounding means.
Old 01-30-2013, 09:29 PM   #5
Rewards Points: 160
why do they even make 2 different things if they are so close in similarity anyway?
Old 01-31-2013, 12:24 AM   #6
" Euro " electrician
frenchelectrican's Avatar
They do look simauir but the bottom line is properly grounded or bonded as some peoples will say that.
The AC cable is not too bad for me to use but you have to be carefull which type of fitting ( connector ) to the metal box this part you can NOT use plastique boxes without bonding jumper on it.
The MC cable is much easier to use and it can use little more variation of fittings without issue. You can use with plastique box (warning.,, please check with your local/state code related to this part some may say no. Only metal boxes with AC cables ) but majorty of my time I use metal boxes without issue.
And the AC cable you will have to use the antishorting bushing on it ( some of electricians will call them red devil or others name for it ) but with MC genrally it don't need antishorting bushing due it do have plastique overwrap in it. but got a habit of doing it.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (01-31-2013)
Old 01-31-2013, 05:59 AM   #7
Rewards Points: 160
i probably only would use ac or mc with metal boxes because that seems like a better idea with metal on metal. ac or mc with plastic boxes doesnt make any sense to me in a good grounding stand point anyway
Old 01-31-2013, 11:17 AM   #8
Rewards Points: 246
Why not just use NM as you have for the switches?
Old 01-31-2013, 06:37 PM   #9
Rewards Points: 160
i could, i just the armor cable with the metal boxes instead of the nm in metal box
Romex conecter question stevo1213 Electrical 5 11-25-2011 12:39 AM
romex conduit question milehigh Electrical 7 07-26-2010 07:55 PM
Quick Question on Powerstrip Install Ferguson Electrical 7 05-06-2010 06:16 PM
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 01:06 PM
"Common Path" limits for Romex -- Code question burro Electrical 4 08-10-2008 03:43 PM
