MC Cable Vertical B/ween Studs Unstapled? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 07:13 PM   #1
Rewards Points: 1,062
Question
MC cable vertical b/ween studs unstapled?
i was wondering it if is OK to have MC cable run vertically between two studs equidistant and not stapled to either stud. it is because i have a cable stapled to both studs in the same space.
is it even necessary to ever staple MC cable considering its armor? i would guess not but i still do it for the neatness of it.
Old 05-27-2011, 07:26 PM   #2
Rewards Points: 512
"330.30 Securing and Supporting.
(A) General.
Type MC cable shall be supported and secured by staples, cable ties, straps, hangers, or similar fittings or other approved means designed and installed so as not to damage the cable."
Old 05-27-2011, 07:32 PM   #3
Electrical Contractor
I hope these help.
http://www.erico.com/public/library/LT0393.pdf
http://www.erico.com/products/CADDYc...mCbleSpprt.asp
hpp58 is offline   Reply With Quote
Old 05-27-2011, 07:47 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
unless fished inside cavities mc cable must be supported. in wood studs staples are the easiest.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 09:04 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Vertical EMT run - Max length and cable support? ScottR Electrical 3 10-06-2008 01:58 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
