MC Cable Terminiation - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 12:21 PM   #1
I bought this http://www.homedepot.com/buy/southwi...specifications
Could someone tell me what I can use to terminate this into an electrical box.
gomike is offline   Reply With Quote
Old 10-11-2012, 12:56 PM   #2
Rewards Points: 734
You're using metal boxes, right?
Try something like this: http://www.homedepot.com/buy/afc-cab...l#.UHb6EVTqXlY
Don't forget your "anti-short" bushing.
http://www.homedepot.com/buy/halex-3...l#.UHb6iVTqXlY
AandPDan is online now   Reply With Quote
Old 10-11-2012, 01:09 PM   #3
the MC I got is 5/16"
Old 10-11-2012, 01:14 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,864
The nominal dimension is 3/8". It's standard 14-2 MC cable.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-11-2012, 01:15 PM   #5
DIY Enthusiast
sublime2's Avatar
In that case I'd suggest you buy the 5/16" connectors.
sublime2 is offline   Reply With Quote
Old 10-11-2012, 01:48 PM   #6
Licensed electrician
Rewards Points: 1,054
Anti-shorts are not required for MC cable.
brric (10-11-2012)
Old 10-11-2012, 01:49 PM   #7
Do you know if they make a screw in for my size
Old 10-11-2012, 01:50 PM   #8
The connectors for 14-2 MC should be readily available in different styles.
Old 10-11-2012, 04:06 PM   #9
I was hoping to use the screw in connectors but can not find in the right size
Old 10-11-2012, 04:17 PM   #10
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
ANti-short bushings are not required.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-11-2012, 05:18 PM   #11
Sparky
Rewards Points: 510
'screw in' connectors for MC cable don't exist.
assuming you're talking about this type
Techy is offline   Reply With Quote
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 09:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
