MC Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 01:23 PM   #1
MC cable
I just purchaed a 6' pre-made cable http://www.acehardwareoutlet.com/Pro...px?SKU=3292257
to run to my fluorescent lights. The knock out on the light itself is 0.5" in diameter and the connectors on the end of the cable are .75". I looked at ACE, HD and Lowes and no one carry's a connector that would fit into the 0.5" hole. Any suggestions?
howard.wheaton is offline   Reply With Quote
Old 01-02-2011, 01:41 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Why do you need this whip? What do you mean you go tit to "run" the lights?
Where are you connecting the other end?
What you are looking for is a 3/8" cable connector. Any electrical supply house will have them.
Speedy Petey is online now   Reply With Quote
Old 01-02-2011, 01:53 PM   #3
I am running the whip from the lights (under the cabinets) up into the cabinet and then through the wall down to a switch (don't want to use a plug). The total length will be 24" at the most. The wip doesnt say AC or MC so not sure what is actually is. It is a 3/8" conduit that just has a green, white, black wire. Are they normally aluminum or steel?
Old 01-02-2011, 01:59 PM   #4
Electrical Contractor
kbsparky's Avatar
Originally Posted by howard.wheaton View Post
.... Any suggestions?
Drill out the hole to 7/8". Problem solved.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
clashley (01-02-2011)
Old 01-02-2011, 02:47 PM   #5
I would prefer a small connector to keep the depth down.
Old 01-02-2011, 03:04 PM   #6
There's probably not going to be much difference in depth between a 7/8 fitting and 1/2" fitting. In the time it will take you to locate a 1/2" fitting, you could use a hole saw to knock out a 7/8" and be done. That's what I did with my shop lights, since the factory knockouts were too small for the cable fittings.
clashley is offline   Reply With Quote
Old 01-02-2011, 05:01 PM   #7
Do they make a flex conduit that is smaller then 3/8"?
Old 01-03-2011, 11:02 AM   #8
Rewards Points: 130
7/8" and 1/2" in the electrical field are the same as far as KO's and holes are concerned. 1/2" connectors require a 7/8" hole.
Old 01-03-2011, 11:14 AM   #9
Rewards Points: 154
depending on where this is you dont need armoured cable, you can use nmd90 for this
awdblazer is offline   Reply With Quote
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
