-   -   maytag top load washer not spinning at times (http://www.diychatroom.com/f18/maytag-top-load-washer-not-spinning-times-91568/)
ed lee 01-06-2011 10:59 PM
Hi,
I need help in getting an answer as why my Maytag top load washer
model MAV1700aww is not spinning dried at times, after the cycle completed,
clothes still dripping wet, when put to spin cycle, motor will sound but not spinning, moved drum & lifted washer & touched belt & pulley & it works again, but the motor seems laboring a bit, this seems to happen every so often, what may be the problem please help. Thank you Ed
DexterII 01-07-2011 11:58 AM
I do not know that I am familiar with that model specifically, but try this. I believe that you may find 2 screws on the front panel, not visible at first glance, but tucked under a "roll", near the bottom of the machine. With the power OFF, remove those screws, and pull the bottom of the panel toward you. Once you pull it out a bit, you should be able to release it from the clips at the top of the machine. Now, if I am thinking right, you should have access to the motor and belt(s), and will see that the motor runs both the drum and the pump. Remove the belts, and check that the springs on the motor are working. You should be able to move the motor toward the center of the machines, but the springs should pull it back, which tightens the belts. If this checks out, my suggestion would be to invest in a belt or belts.
RST 01-07-2011 12:37 PM
It could be a bad clutch. Try asking at a local appliance parts store, they are usually helpful.
