May Be A Silly Question, But..... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2008, 12:58 PM   #1
the Musigician
DangerMouse's Avatar
Question
may be a silly question, but.....
hi everyone!
i've seen pictures of outlets with the ground hole UP, and with the ground hole DOWN... is there a code specified way? also, just nailing 2 nails to the stud for an outlet box seems a bit weak, is it ok to drill a hole in the side and add a screw for extra support? lastly, (for today anyway) the holes drilled through the floors to run the romex need to be to be filled with (insert correct substance here) to halt air flow between crawl space and walls.
thank you for your time!
DM
Old 07-20-2008, 01:27 PM   #2
Whatamess
Up or down doesn't matter you can put a screw in the side. Not suppose to but no harm. If you want air tight GreatStuff works good. Not required.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-20-2008, 01:50 PM   #3
the Musigician
thanks!....this inspector is full of himself and will hit me on any little thing wrong, so i need to be certain. when installing a light switch, always use the black wire? yes? for hole filling i was thinking more along the lines of a caulk gun and some silicone? great stuff is freat, but it has it's drawbacks too... =o/
DM
Old 07-20-2008, 02:31 PM   #4
DM
Yes, the switch always goes on the hot (black) wire. It also needs to have a ground wire connected to the box, or if a plastic box, then to the ground of the Romex cable.
FW
fw2007 is offline   Reply With Quote
Old 07-20-2008, 02:39 PM   #5
the Musigician
thought so, thanks! what about the caulk?
DM
Old 07-20-2008, 03:12 PM   #6
Master Electrician
JohnJ0906's Avatar
If your inspector is a stickler, don't screw through the sides of the boxes. IMO, that is technically a violation, and he might see it that way also.
2 nails have always held boxes very secure for me...
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-20-2008, 03:20 PM   #7
Power Gen/RS Engineer
Rewards Points: 566
So, what would he say if you installed all of the receptacles horizontally?! I've seen a local trend toward this. Then we'd all be arguing as to which blade should be on top
Sounds like your inspector may have a Napolean complex or short wee-wee...
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 07-20-2008, 03:26 PM   #8
Master Electrician
JohnJ0906's Avatar
The funny thing is, all of the "pro" electrician forums lock any threads started that ask this question. (Not to say that is is a bad question)
It's just that there is no "right" answer, but we will debate it to death anyway....
John from Baltimore
One Day at a Time
Old 07-20-2008, 03:36 PM   #9
Whatamess
caulk will be fine.
Old 07-20-2008, 05:44 PM   #10
Electrician
Around here I have to use a draftstop product, not some silicon off the shelf.
So its more of a building code than anything.
chris75 is offline   Reply With Quote
Old 07-20-2008, 05:52 PM   #11
Don't know it all, yet!
An old electrician once told me that he always installed the ground up. That was in case (not likely, but maybe) you had a plug partially unplugged and dropped something against it, it would hit the inert ground instead of a hot contact. If horizontal, he would install with the common up.
Just one of those things somebody showed me one time who's done it a lot more than I have.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 07-20-2008, 05:59 PM   #12
Electrician
The thing I never got with installing the ground up and the if something ever got dropped scenario, is so what, now that object hits the ground first and now has a 50/50 chance of still falling against the ungrounded conductor and still short...
Old 07-20-2008, 06:07 PM   #13
Registered User
Termite's Avatar
Receptacle orientation is purely preference. There's no code to substantiate it. There are instances where you can't place them face up (kitchen countertops, etc).
Drilling the hole in the side of the box would in fact be a code violation. You cannot modify a listed product in any way. Whether or not it is going to make a difference is debatable.
Why are you being critical of the inspector, who is doing his job and being thorough? The way I see it, he's advocating for you...The owner and occupant of the house. If he goes easy on you he's doing you and any future owner a disservice. No offense, but you're asking which wire to switch...Electrical basics...Which makes me think that a thorough inspection is the best thing for you. Take the fact that he's a little full of himself with a grain of salt (personality issue) and encourage him to look at your work with reasonable scrutiny.
Old 07-20-2008, 06:33 PM   #14
Res Ipsa Loquitur
These boxes CAN be screwed thru the side legally and within code... Arlington Industries non-metallic box-
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 07-20-2008, 06:40 PM   #15
Registered User
Termite's Avatar
I've seen them, and they're nifty. Very good for homeowners and DIYers. Just to be clear though, we're saying that you can't drill a hole in a box (thereby modifying it) to facilitate installation of a screw. If the box comes with holes already in it, those holes can be used at will.
Tags
outlets
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
