May I Switch An Acid-lead Battery With A Lithium-ion Battery? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2013, 03:28 PM   #1
Rewards Points: 30
May I switch an acid-lead battery with a lithium-ion battery?
Hello, this is my first post on this forum, I hope you can give me a hand on this:
I'm photographer and I own an lighting equipment that's battery operated and that works with a 12v 7.5 acid lead battery. I was wondering if it was possible to switch the battery for this one, wich is a Li-ion battery:
http://www.hollyhockbatteries.com.au...e_Battery.html
Is there any advantage in doing this? More power? More lightweight? etc.
panchoskywalker is offline   Reply With Quote
Old 06-13-2013, 03:49 PM   #2
MarginallyQualified
Rewards Points: 2,464
Volts is volts.
If both have the same output then where it comes from shouldn't matter.
I'd still suggest that you ask the lighting equipment maker first though.
Old 06-13-2013, 03:58 PM   #3
Rewards Points: 258
The lithium ion battery has a longer amp curve in other words your lights with stay brighter longer but watch how you recharge the battery to hot and it will explode
redman88 is offline   Reply With Quote
Old 06-13-2013, 03:59 PM   #4
Rewards Points: 746
You'll need a different charger. If it's built into the device don't even think of putting in the li-ion battery.
AandPDan is offline   Reply With Quote
Old 06-13-2013, 04:08 PM   #5
Rewards Points: 30
The charger is built inside the device, but I understand that the li-ion should be recharged with another special charger.
In thems of power would the Li-ion battery last 2 times longer, 3 times longer? Would there be a big difference?
In therms of weight, would it be lighter?
Old 06-13-2013, 04:44 PM   #6
Rewards Points: 746
A 12v 7.5 amp/hr battery of either chemistry has the same capacity but the discharge curves are different.
Old 06-13-2013, 04:49 PM   #7
Rewards Points: 30
Ok, so the question I should have asked is (maybe) if I could swap the lead-acid battery with a higher capacity Li-ion battery?
Old 06-13-2013, 04:52 PM   #8
Rewards Points: 746
Or a higher capacity lead acid battery and avoid the charging problem.
Old 06-13-2013, 04:57 PM   #9
Rewards Points: 30
The device wouldn't accept bigger battery and the if it did weight would increase, I'm lookin wether to gain capacity or loose weight (or both).
Old 06-13-2013, 05:12 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Lead Acid? Are you sure it's not a gel cell battery? Or is it a car battery?
Just so you understand, there is a BIG difference in charging methods for Lead Acid vs Li.
I would start with the manuf of the lighting equipment.
Old 06-13-2013, 05:13 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,902
That's 10 times the cost of a comparable lead-acid battery. The performance will be essentially identical. The only difference is weight. Is reducing the weight worth that much?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 06-13-2013, 05:14 PM   #12
Rewards Points: 746
Is it a SLA battery? Sealed lead acid?
Old 06-13-2013, 05:23 PM   #13
Rewards Points: 30
Yes, the device works with this kind of battery:
pdf: http://www.ultracell.co.uk/datasheet...s/UL7.2-12.pdf
The charging process is not an issue as I can take the battery in and out very easily so I can charge it with another charger.
Old 06-13-2013, 05:30 PM   #14
Rewards Points: 746
Why not just by another battery? I know it's awkward to carry two but it's a lot cheaper and you'll have no problems charging it.
Old 06-13-2013, 05:32 PM   #15
Rewards Points: 30
Well, your answer make sense, I guess the answer is No, but If I can get 10 times the capacity for the same weight then maybe the answer is yes.
Cut off switch for car battery blowing fuses IAmSupernova Electrical 141 05-28-2013 09:48 AM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 06:31 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
