Maximum Wires Through J/B Cable Clamp? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 01:28 PM   #1
the Musigician
DangerMouse's Avatar
Maximum wires through J/B cable clamp?
What is the max amount of 12-2 romex wires allowed through a single 1" J/B cable clamp?
I hope it's 2 at least... Po)
DM
EDIT: This thread contains much more helpful info as well as the answer to my question, be sure to read it all! Many thanks to all who contribute(d)!
Old 07-27-2010, 02:11 PM   #2
Electrician
Proby's Avatar
It depends on the clamp.
We've got worse things to worry about. Don't tighten the clamp too tight and you're good to go. No, I did not just say that
Proby is offline   Reply With Quote
Old 07-27-2010, 02:17 PM   #3
the Musigician
standard 1" clamp... 2 screws.... 3 wires will fit through....
2 wires ok?
DM
Old 07-27-2010, 02:49 PM   #4
Electrician
Proby's Avatar
I'm really not sure what you mean by a clamp. Originally I thought you were talking about an integral clamp in a JB, but now it sounds like you are talking about a romex connector, altho 1" is not very common for residential.
Ultimately, it depends on the connector/clamp's listing.
Old 07-27-2010, 03:01 PM   #5
the Musigician
Plain ol' steel J/B with romex clamps... 1" hole in box.
Looks like this here..... Po)
DM
Maximum wires through J/B cable clamp?-j-box1.jpg
Old 07-27-2010, 03:21 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
DM, I hope that is not your work.
Old 07-27-2010, 03:33 PM   #7
Electrician
Proby's Avatar
Ok, those are 1/2" Romex connectors. The hole in the box measures 7/8" which is the actual size of a 1/2" knock out.
Again, the amount of cables allowed in a connector is decided by the manufacturer.
Is that the box in question? Are you looking to add another cable to it? If so, get rid of it and get a deep 4" square box which will give you many more KO's to use and be bigger enough for all those wires. Also, cut back the sheath so it's not going into the box. You want the individual conductors to be longer, it's easier to work with. And I'd like to see one single splice of the ground wires in that situation. From the looks of it there are three splices and a tail.
Old 07-27-2010, 04:34 PM   #8
The cable clamps that I install are rated for (2) 12-2 cables
I was thinking the clamps already installed on some boxes
Old 07-27-2010, 04:41 PM   #9
the Musigician
OK, I now know this J/B is undersized for the amount of 12-2 wires. (6 max...Thanks Petey!)
I'll get bigger and do it right once I figure it out.
DM
Old 07-27-2010, 08:02 PM   #10
You can use a 4" sq box, 2-1/8" deep, with a round mud ring on it, since you are installing a fixture to this box.
Old 07-27-2010, 08:46 PM   #11
the Musigician
What is a 4" mud ring that accepts standard ceiling fixtures? Got a picture or a link? I can't see anything on google that looks right.
Thanks!
DM
Old 07-27-2010, 09:35 PM   #12
Electrician
Proby's Avatar
Are you installing a fixture on this box? If so, you can use the attached cover. If not, just use a blank cover.
The Following User Says Thank You to Proby For This Useful Post:
Speedy Petey (07-27-2010)
Old 07-28-2010, 12:21 AM   #13
" Euro " electrician
frenchelectrican's Avatar
There is one nice gotcha you can not use the ceiling fans with the 4 inch sq mud ring for it unless you make a bracket or super long lag bolts to slam into the duex par quatre { 2X4 stud } then it will be legit but not the screw of the mudrings they are only 8-32 size.
Merci.
Marc
Old 07-28-2010, 07:25 AM   #14
the Musigician
This box will just hold up a flushmount light fixture, but I have 2 more to do that WILL hold small ceiling fan/light combos.
What box is made specifically for ceiling fans? Any pics?
Thanks!
DM
Old 07-28-2010, 08:16 AM   #15
Electrician
Proby's Avatar
Thanks!
DM
There's a bunch of boxes, just swing by Home Depot and you'll see many. Everything from a normal box like what you currently have (just a little beefier) to pancake boxes to plastic saddle boxes that hug the underside of the joist. Pick out something you like and make sure that it says "Fan Rated" on it and you're good to go.
DangerMouse (07-28-2010)
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Maximum wires in a junction Box Tcal Electrical 8 09-16-2007 06:15 PM
