Old 03-17-2008, 12:34 PM   #1
Maximum Ampacity for Aluminum Feed
What is the maximum ampacity rating for #000 three-conductor aluminum?
Randell Tarin is offline   Reply With Quote
Old 03-17-2008, 12:48 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
In general terms the maximum is 175 amps but may be less depending on how you are using it and the insulation covering of the wire and the terminal temperature rating of the equipment your connecting to.
Old 03-17-2008, 12:57 PM   #3
It's underground feed to a sub-panel. We've been through this before in another thread on the proper way to set up this particular panel. However, my original requirement for a 100 AMP sub has grown to 125 AMP.
I just wanted to make sure I had it covered with the feed. Otherwise, I was going to have to scale things back on my total load.
Old 03-17-2008, 01:15 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
You may have an issue with connecting 3/0 to the mains of a 125 amp load center.
Old 03-17-2008, 01:19 PM   #5
How so? Are you talking about wire size in the main breaker?
Old 03-17-2008, 01:32 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Yes. I also doubt you will easily terminate that 3/0 anywhere in a 100A panel.
Old 03-17-2008, 01:48 PM   #7
OOPs! My Bad. It's 1/0 not 3/0.
I ran the feed several months ago and kind of forgot what I had. I just now compared the wire size with the main breaker opening. It fits.
However, back to my original concern. Maximum amperage for 1/0 Aluminum.
Old 03-17-2008, 01:50 PM   #8
125 Amps
Old 03-17-2008, 01:57 PM   #9
By the skin of my teeth!
I'm sure I won't exceed 125 AMPs on this panel, in fact it probably won't exceed 100 amps, so I have a little flex built in.
Thanks guys.
feed to subpanel question JCA1 Electrical 1 03-11-2008 09:16 PM
main line to feed attic qnzkrew HVAC 3 12-28-2007 04:54 PM
RSS Feed Help DeeTee Site Help and Suggestions 1 08-30-2007 08:39 PM
