Old 03-08-2007, 08:01 PM   #1
material for goosneck lamps
Hey guys, quick question.
I am starting a lighting project in my spare time and I was curious if any of you guys know the what the bending material on gooseneck lamps is called(check picture). If any of you guys know what it is called/where I could buy it that would be greatly appreciated. Sorry if this is in the wrong forum and thanks in advance.
sweatshirtbrigade is offline   Reply With Quote
Old 03-09-2007, 06:02 AM   #2
They are called tubing benders. Usually they are specific to the type of tubing you are bending and size.
Sizes for common benders are trade size not the actual size that you can measure with your ruler so it can be confusing to find the right one, but If you have say 1/4 in tubing for example then you need a 1/4 inch bender.
Most benders come with a pre defined radius. If you are building lamps you will want to decide your own radius. I suggest spring type bender that slides inside the tubing. Then you can shape the tubing by hand and pull the spring out last. I cant remember the name for that particular style bender, but they are available on the net and at plumbing supply houses.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-11-2007, 01:55 PM   #3
Power Gen/RS Engineer
From the picture, it looks like this lamp has a flexible neck. If so, try the following website: http://www.profhdwr.com/08412.htm
Good luck,
Jim
BigJimmy is offline   Reply With Quote
Non-Slip Material dolver Interior Decorating 1 07-05-2007 08:57 PM
3-way lamps - my headache panoply Electrical 1 04-16-2007 05:32 AM
Outdoor Post lamps tennisnut Electrical 4 10-16-2006 03:48 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 08:30 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
