Old 07-01-2011, 07:26 PM   #1
Matching 220 3-wire cord to 220 range
I have a 50 amp breaker feeding a 3wire 220V (black, white and ground) receptacle. The new range has a black, a white and a red wire where the white is grounded to the frame. How do I attach the cord leads to the range wires (nuts) so that I don't fry my new range.
Thanks in Advance!
FrankD is offline   Reply With Quote
Old 07-01-2011, 07:52 PM   #2
biggles's Avatar
if that ground is raw copper that is a 115V 2 wired socket with a black and white.......black,red and white are 220V black is 115v to ground and so is red between red and black are 220V do you read 220V on the exsisting socket
Old 07-01-2011, 08:05 PM   #3
Electrician
SD515's Avatar
Like this picture…
The neutral (white) is usually the center wire. It should have ribs running the length of the cord. The outer 2 get hooked to black and red, doesn’t matter which.
Kyle
Old 07-01-2011, 08:25 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Unless this is type SE cable it is wrong and should be corrected. A bare ground in NM cable should not ever carry neutral current.
Old 07-01-2011, 08:32 PM   #5
Electrician
SD515's Avatar
Good point Speedy. I guess I assumed it was SE feeding the receptacle. I was commenting on the cord, but good catch.
Kyle
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Extending wire for electric range rovers1973 Electrical 3 03-17-2010 05:09 PM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 06:39 AM
range wire size mikalino Electrical 11 02-12-2009 09:52 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
