-   -   Matching 220 3-wire cord to 220 range (http://www.diychatroom.com/f18/matching-220-3-wire-cord-220-range-109397/)
FrankD 07-01-2011 07:26 PM
I have a 50 amp breaker feeding a 3wire 220V (black, white and ground) receptacle. The new range has a black, a white and a red wire where the white is grounded to the frame. How do I attach the cord leads to the range wires (nuts) so that I don't fry my new range.
Thanks in Advance!
biggles 07-01-2011 07:52 PM
if that ground is raw copper that is a 115V 2 wired socket with a black and white.......black,red and white are 220V black is 115v to ground and so is red between red and black are 220V do you read 220V:huh: on the exsisting socket
SD515 07-01-2011 08:05 PM
1 Attachment(s)
Like this picture…
The neutral (white) is usually the center wire. It should have ribs running the length of the cord. The outer 2 get hooked to black and red, doesn’t matter which.
Speedy Petey 07-01-2011 08:25 PM
Unless this is type SE cable it is wrong and should be corrected. A bare ground in NM cable should not ever carry neutral current.
SD515 07-01-2011 08:32 PM
Good point Speedy. I guess I assumed it was SE feeding the receptacle. I was commenting on the cord, but good catch.
