Massachusetts Code On Smokes - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2010, 10:21 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Massachusetts code on smokes
I was planning on adding smoke/CO detectors to a general 15A lighting circuit. Is this code compliant in MA or do smokes need a dedicated circuit?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-12-2010, 11:04 AM   #2
Rewards Points: 77
Hey,
I am doing the same thing currently. I believe that they do not want them on a dedicated circuit because if it trips you may not realize. If it is on a circuit with lights, you would know the circuit tripped from the lights. I am planning on using the three way hall light to run the smokes. May want to still double check. If you find anything out post it back, cause I am curious, but that it what I have been led to believe.
gregt848 is offline   Reply With Quote
Old 03-12-2010, 11:05 AM   #3
Rewards Points: 77
I am in Mass. too
Old 03-12-2010, 11:34 AM   #4
I have always thought they do not want them on a dedicated circuit, since they could then be shut off
I've been looking for something that fulle explains requirements
Its a Fire Code regulation as far as I know
Not even Mass Gov had info
Some info...& info on different types of detectors - from REMax
I may end up buying different types for a good mix of detectors
http://www.sellmyhomeinmetrowestma.c...e_2247659.html
Old 03-12-2010, 11:36 AM   #5
527 CMR 32 outlines requirements:
http://www.mass.gov/Eeops/docs/dfs/o...red/527032.pdf
But doesn't address the issue
When my last house was sold I think the Lt that did the Inspection stated they could not be on a dedicated circuit
I had battery operated & they wanted hard wired
Another pamphlet
http://www.mass.gov/Eeops/docs/dfs/o...m_printout.pdf
Old 03-12-2010, 11:38 AM   #6
I have gas!
I'll call the building office this afternoon.
A friend that lived in Beverly, MA was required to wire his on a dedicated circuit but it might have been a misinformed inspector.
Old 03-12-2010, 11:48 AM   #7
Maybe not....but just info from a commission:
Start on page 18 (by pamphlet)
http://www.cpsc.gov/LIBRARY/FOIA/foi.../acfismoke.pdf
NFPA 72 addresses the installation of smoke alarms in residential homes. The 2002 National Fire Alarm Code, Section 11.6.3 AC Primary Power Source, states:
The ac power source shall comply with the following conditions:
(1) A visible “power on” indicator shall be provided.
(2) All electrical systems designed to be installed by other than a qualified electrician
shall be powered from a source not in excess of 30 volts that meets the requirements for power-limited fire alarm circuits as defined in NFPA 70, National Electrical Code, Article 760.
(3) A restraining means shall be used at the plug-in of any cord-connected installation.
(4) AC primary (main) power shall be supplied either from a dedicated branch circuit or the unswitched portion of a branch circuit also used for power and lighting.
(5) Operation of a switch (other than a circuit breaker) or a ground-fault circuitinterrupter shall not cause loss of primary (main) power.
Exception: Where a ground-fault circuit-interrupter serves all electrical circuits within the dwelling unit
Old 03-12-2010, 02:00 PM   #8
I have gas!
It would be a Massachusetts ammendment. NEC allows it to share a branch circuit.
(4) would have been easier worded as:
"AC primary (main) power shall be supplied by an unswitched branch circuit."
I Forgot it is Friday and the building office closed at 12:30. I'll update this thread on Monday.
Old 03-12-2010, 03:07 PM   #9
Rewards Points: 320
I am also in Mass. Check with you city/town FD. We require them to be on a general lighting circuit so that if it trips you will know about it and will likely fix the problem as opposed to shutting it off and forgetting about it.
teamo is offline   Reply With Quote
Old 08-11-2010, 07:41 PM   #10
I have gas!
Following up finally.
I checked with the electrical inspector. He told me dedicated and it was code. I'm debating if I should challenge him on this. I don't want to tick him off but I'd rather the smokes be on a lighting circuit.
Edit: I'm going to check with the local FD. Who should I ask for? I don't imagine that all firefighters would have this info.
Old 08-11-2010, 08:02 PM   #11
Electrician
Proby's Avatar
Why would you like them on the lighting circuit? The battery backup will beep when power is lost to let you know.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-11-2010, 08:19 PM   #12
The reason I was told that they didn't want them on a dedicated circuit:
It could trip or be shut off
Batteries could be removed if someone had nuisance alarms & did not want to buy new smokes
If they shared a lighting circuit less chance they would be shut off
That was over 7 years ago at my last house
Didn't matter to me....I just wanted to wire them up & be done
Old 08-11-2010, 08:59 PM   #13
I have gas!
Good point, follow the path of least resistance.
Old 08-11-2010, 09:07 PM   #14
Mine (both houses) are on a lighting circuit
A dedicated just seems like a waste of a breaker
Old 08-12-2010, 12:18 AM   #15
" Euro " electrician
frenchelectrican's Avatar
I know in Wisconsin the Smoke dectectours are on the lighting circuit ditto with French Electrical code as well.
Merci.
Marc
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
Help with Massachusetts Stair Code, please! wombosi Building & Construction 6 02-17-2009 09:41 PM
code details for boxes kama Electrical 6 01-30-2009 11:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
