Marine Stereo Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 10:24 AM   #1
marine stereo wiring
trying to wire marine stereo directly to battery (through inline fuses). Can you confirm the wiring sequence. Red to positive terminal, and so on. the haress has red, black, blue and yellow.
burt dow is offline   Reply With Quote
Old 05-25-2011, 10:35 AM   #2
Rewards Points: 1,578
What do the instructions from the unit say to do?
bob22 is offline   Reply With Quote
Old 05-25-2011, 10:41 AM   #3
Rewards Points: 252
What brand is the radio?
Marty1Mc is offline   Reply With Quote
Old 05-25-2011, 11:16 AM   #4
(the original)
Rewards Points: 756
Red= switched power
Yellow= continuous power source (memory)
Black= ground
Blue= accessory, probably amp in this case
ratherbefishin' is offline   Reply With Quote
Old 05-25-2011, 11:16 AM   #5
Most aftermarket head units (including marine ones) have a standardized color code for the wiring.
Yellow is the constant on battery 12V
Red is the ignition 12V that should only be on when the ignition is on
Blue is for a power antenna.. it sends a 12v trigger signal only when the radio is on
Blue/white is a remote amp turn on, similar to the power antenna, except it sends a 12v trigger signal whenever the head unit is on
Orange is for dash illumination/dimmer. If your head unit has it, it'll dim the lights on the head unit when you turn on the headlights. Don't hook that one up.
If the head unit only has a blue (and no blue/white) than that is for the remote amp turn on, instead of only for a power antenna.
Here's a diagram I found for all the wiring color codes for all the speakers, etc.
Good luck!
homerb is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
12 volt marine wiring - can anyone help? arichard21 Electrical 6 11-29-2007 05:47 AM
