Mapping Out For Re-wire - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 03-17-2014, 11:09 AM   #1
Rewards Points: 300
Mapping out for re-wire
Im remodeling my home and I havent quite got as far as re-wiring the upper level yet but I did make a list of what will need to be done.. Just wanted to get input on what everyone thinks should be grouped together and what not... Any info would be appreciated...
Bedrooms 1/2 - 2 ceiling fans w/lights and roughly 10-12 outlets
Bathroom - 1 gfi outlet, 1 light above the sink, and 1 exhaust fan/light in ceiling
Hallway light outside the bathroom and 1 outlet down farther towards the family room
Light above staircase inside front door
Outside light above front door
Family room - 4-5 outlets and I havent installed any lights in the ceiling but would like to put in like 4 potlights
Dining room isn't very big so its 1-2 outlets and a ceiling fan/light
Kitchen - 1 outlet for fridge, 1 gfi for toaster which is on one side of the sink,1 outlet in cabinet for microwave, one outlet on other side of the sink and also 1 outlet behind the stove... There is track lighting installed right now but that's going to get taken down for 4 potlights more than likely....
timothy300858 is offline
Old 03-17-2014, 11:19 AM   #2
Rewards Points: 13,266
http://www.ask-the-electrician.com/e...e-outlets.html
I'd keep the lighting and outlets on different circuits.
100% sure your local codes do not call for AFCI breakers, hardwired smoke detectors or conduit?
Stairwells need a three way switch at top and bottom of the stairs.
joecaption is online now
Old 03-17-2014, 11:24 AM   #3
I am
1 or 2 circs.up to you (got room ac window units) 15 0r 20 amp
1 circ 20 amp (or do recept on 20 amp..... and take from a 15 amp for lighting/fan)
could put on with the 1 or 2 beds 15 Or 20 amp
Dining room a ceiling fan/light
lighting and recpts in living room 1 , could also do your oustide lighting. 15 0r 20 amp
4 or 5 circs. (2 appliance, micro,frige,. Dining recpts. can go on appliance if you want) 12's 0n 20 amp, don't forget dw
(exception... fridge can be on a 15... also dw can)
not allowed on kitchen recepts..
new circ or add to living room.. 15 0r 20amp
suggestions.....
12 sux to work with.. (more expensive, box conductor fill, finger jarring)
12's on 20 amp..
all kitchen appliance, dining, bath, and laundry receptacles.
14's on 15 amp..
all lighting (sept bath if you bring a 20 to bath and do recpt,light,fan)
living rm,bed,hall,outside receptacles...
njoy
UnclePhil is offline
Old 03-17-2014, 11:48 AM   #4
Oso954's Avatar
Rewards Points: 740
Read the link that Joe posted.
You don't have enough receptacles in the kitchen ( unless you are real short of counter space) or the dining room. I would also question the family room.
You mentioned an outside light at the front door. What about other exterior doors ?
Oso954 is offline
The Following User Says Thank You to Oso954 For This Useful Post:
UnclePhil (03-17-2014)
Old 03-17-2014, 11:55 AM   #5
Rewards Points: 300
I plan on reading the link as soon as I get other things done Im working on. I have a total of 5 outlets in the kitchen with one being a GFI and one being in the cabinet for the microwave. And its an open floor plan so it all flows together. There is only one outlet technically in the dining room that isnt very big. If I knew how to post pics of the rooms, I would. I know that would make things easier. There is a light outside the slider door on the deck, a light above the front door outside. And there is also a light above the back door of the garage and two in the front of the garage that are wired in from the garage that arent in question.
Old 03-17-2014, 12:16 PM   #6
Rewards Points: 1,989
Best I remember , you are required to have at least 1 outside receptacle and it requires GFCI protection ?
God bless
Wyr
WyrTwister is offline
Old 03-17-2014, 12:25 PM   #7
I am
God bless
Wyr
At one time..
now two.. front and back.
will check, but that's what memory serves
Old 03-17-2014, 12:31 PM   #8
I am
yep......two.......
Also realize, this is a reno... he doesn't have to install as if new.
Would be nice and suggested to but...
Old 03-17-2014, 12:34 PM   #9
Rewards Points: 300
Well I am re-siding and the whole bit so adding outlets outside wouldnt be a big issue I dont think. Im assuming there is somewhere I can find out as to where they should go... Possibly one in the deck area and one on the front of the house??? Im not so sure on that tho...
Old 03-17-2014, 01:32 PM   #10
I am
;- ) one in the front, one in the back.... anywhere you want..
you could have more than that too..
The Following User Says Thank You to UnclePhil For This Useful Post:
timothy300858 (03-17-2014)
Old 03-17-2014, 03:54 PM   #11
Rewards Points: 300
Just wanted to let anyone know I added pics to my profile if you wanted to look at what I have going on.
Old 03-17-2014, 04:14 PM   #12
I am
1) if you're going to do the flip thing......or even stay and sell down the road.
realtors do compare how the house was and the way it is now.
meaning they do get in touch with the town and what was there and what is
now there..to see if there where permits and inspections and to see if
everything was done right on the work.
2) it may be tough over the internet to know who you are, but documenting the
things you do sometimes may come back and bite you in the ars.
Nice what your doing, but pretty sure people here have seen this type of thing before. Don't overextend yourself is all I'm saying.
Not for you to cop an attitude... just letting you know...
Old 03-17-2014, 04:36 PM   #13
Rewards Points: 300
Yeah I understand what you are saying... I guess I will cross that path if it ever comes to it.... And Im not saying Im doing anything special.. Just adding pictures because someone asked for them before.. No worries
Old 03-17-2014, 05:36 PM   #14
Rewards Points: 512
Where's the pics; I don't see them anywhere, including in your profile?
Installation is the Reverse of Removal.
sirsparksalot is offline
Old 03-17-2014, 07:29 PM   #15
Rewards Points: 300
Sorry man... I decided to take em all down...
Closed Thread
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
