Mandatory Auxilliary Fan Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 01:56 PM   #1
Handyman
Rewards Points: 512
mandatory auxilliary fan switch?
Well, I ran into another house in a new development with a similar situation. Both houses have a switch located in the dining room about 3 ft. from the floor. The first house (this was last year) had the switch and nobody could figure out what it was for. By sheer chance we found it activated the upstairs ensuite fan. Ok, weird enough. This house has the same set up...again 3 ft. from the floor and activates the fan in the upstairs ensuite.
The customer was told by the builder that he is obliged to install these in the event of a gas leak. Is this really a code? In Canada OR the US? Her neighbours don't have this and I have been to many new homes without it as well.
I am trying to figure the logistics as to what she was told. If you suspect a gas leak, I would think the last thing you would do is turn on a switch of any kind. Also, opening a window just makes more sense, or leaving entirely and calling the FD.
canadaclub is offline   Reply With Quote
Old 08-11-2010, 02:07 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If I Recall it correct in the USA I really doubt about with that switch set up and I don't actally run into like that in USA and France at all.
However., for gaz leak very simple open the window and call the Département de Feu { Fire Department }
And you can able check with your local building officals for latest info with the code with this issue.
And I know from my experance some airtight house they will have automatique air exchanger so either any exhaust fan or furnace kick on it will come on so somewhere in the house there will be aux fan relay to kick the air exchange unit.
Merci.
Marc
Old 08-11-2010, 03:00 PM   #3
Handyman
Rewards Points: 512
Merci Marc.
This is a manual decora switch...looks like a regular light switch. Being 3 ft from the floor I am figuring its for a child's access. Like the CDN government, its there, seems logical in a way, but ultimately serves no real purpose other than an added cost.
I hope Andrew reads this. He might be familiar with this and has seen it since he is in Toronto, but anyone from the states ever heard of it?
Old 08-11-2010, 04:26 PM   #4
Electrician
Proby's Avatar
I've never heard of it.
What is an ensuite?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-11-2010, 04:31 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I'm in Canada and I never heard of this either. In fact, the last thing you want is gas fumes being sucked through a fan, because the motor of that fan may be causing small sparks if it's a brush motor, then KA BOOM. Opening a window, not touching anything electrical or metal is probably the best bet, then calling the FD, or if you can, shut off the gas outside and don't open it till the leak can be found.
There would still be gas left over in the line but hopefully a pilot light somewhere would burn most of it out.
Old 08-11-2010, 05:52 PM   #6
Handyman
Rewards Points: 512
an ensuite is a bathroom off of a bedroom, usually a master sometimes other bedrooms.
What intrigued me is that the switches were not installed in the same gang box...they purposely installed the switch a foot lower, properly wired 3 way to the ensuite fan...separate box and all. As I mentioned, its like it was meant for a child or perhaps a handicapped access.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
