Making Switched Outlet Un-switched - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 09:02 AM   #1
Making switched outlet un-switched
Under my sink there is an outlet that the garbage disposal plugs into that is controlled by a switch. It is a duplex outlet, and both sockets are controlled by the switch. I want to add a dishwasher where there has never been one before. How can I make one of the sockets stay switched, but the other one always hot for the dishwasher ?
barley is offline   Reply With Quote
Old 11-11-2011, 09:20 AM   #2
You are best to pull the outlet out, then take a picture of the wires in there.
Then outlets have little "tabs" between the 2 screws on one side. Are you familiar with cutting that tab so the top and bottom outlets are no longer connected? And are you familiar with which is the hot side of the outlet and which is the neutral side?
Then do you know how many amps this circuit is? 15 or 20? It would say on the breaker.
Also do you know if that circuit goes only to the garbage disposal?
Billy_Bob is offline   Reply With Quote
Old 11-11-2011, 09:24 AM   #3
Yes, I am familiar with the tabs to seperate the receptacles, and also know which is hot and nuetral. This circuit is 20 amp, I am not sure off hand if it is just for the disposal though, I will have to check that when I am home a little later.
Old 11-11-2011, 10:22 AM   #4
Does the power come into the switch first or the outlet first?
CheapCharlie is offline   Reply With Quote
Old 11-11-2011, 01:21 PM   #5
joed's Avatar
Rewards Points: 11,516
If you only have two wires in receptacle box you can't do it without pulling a new cable. If you have two black and two white or a red wire then you can probably do it.
Old 11-11-2011, 01:34 PM   #6
If the power comes into the switch, you're SOL (unless you can easily run a 14/3 from the switch to the recept). If it comes into the receptacle first, you can do it.
Switched outlet bryanp22 Electrical 1 11-02-2011 06:51 AM
how do I make the last outlet switched? dancram Electrical 5 10-26-2011 10:30 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
