Old 07-31-2011, 08:14 PM   #1
making string lights
I want to make a few sets of string lights, something that looks substantial.
I wanted to know if there is anything i should know or consider before i start. I am going to buy some waterproof lamp sockets and some lead. I have a few outlets in the back and plan on plugging them in directly and using a timer. I am definitely a beginner.
dad1166 is offline   Reply With Quote
Old 07-31-2011, 10:10 PM   #2
Are these walnut sized Christmas tree style lights, miniature pencil eraser sized Christmas tree lights, standard light bulbs, or "rope" lights inside a flexible transparent plastic tube?
Standard light bulbs can shatter if they are hung outdoors and rain gets on them when they are turned on.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 07-31-2011, 10:15 PM   #3
Standard bulbs, maybe ill buy some outdoor bulbs. I have a few dollars to spend on this project
Old 07-31-2011, 10:16 PM   #4
Framing Contractor
You can buy a nice set of string lights at an electrical supply house. Probably not more than $40 for a 10 light string.
sixeightten is offline   Reply With Quote
Old 07-31-2011, 10:19 PM   #5
I need a few 20 ft strands and I want to make it myself just for fun
Old 08-01-2011, 07:44 AM   #6
You will need to use wire nuts or similar clamping devices to make the connections. Do not rely on the wire nuts to support the weight of the string.
Often knots are tied in the wires "of the string" to provide mechanical (physical) support. Then the actual connections with wire nuts don't get pulled on. This is for temporary use only because over time the insulation in the knots will wear through. Also the temporary nature of this arrangement forgives the unattractive appearance of the knotted wires. Another alternative is using a rope to provide support and wrap the wires around the rope not too tightly (or use cable ties).
Chances are it will take many hours of labor to make something that looks as good as the string of work lights you can buy for the $40. mentioned previously.
Old 08-01-2011, 08:46 PM   #7
Missouri Bound's Avatar
There are light sockets made for this application. The base of the socked unscrews revealing 2 sharp pins. The wire is laid into a groove in the bottom of the socket and when the base is screwed back on it pushes the wire into the pins. These sockets usually have a wire hook on them for hanging. Get the right size wire, observe polarity and you should be fine. (still probably cheaper to buy the ready made set)
Old 08-02-2011, 09:08 AM   #8
WDR
Yes they make sockets and I have seen them at most standard hardware stores around hear for about $2.00. Look up temporary light socket to find them online.
WDR is offline   Reply With Quote
Tags
string lights
Two Lights, Two Switches Headache darveaux Electrical 13 01-21-2011 12:47 PM
Fluorescent lights multiple carpenterty Electrical 13 12-04-2010 12:26 AM
Landscape lights BlueBSH Landscaping & Lawn Care 2 02-24-2010 10:43 PM
How to test many 'dead' string of xmas lights? Leah Frances Electrical 8 01-27-2010 09:21 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
