Making Sense Of Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 11:03 PM   #1
Making sense of wiring
Any help on this would be greatly appreciated - the previous owner's replacement of switches was, let's say, random. Here is my puzzle:
It is a three way switch. The light fixture has been removed as well. I've currently got:
Switch 1 - a dimmer (three-way)
Box has one cable coming in with red, white, black
Switch 2 - non-dimmer three-way
Box has three cables entering:
Cable 1: red, white, black
Cable 2: red, white, black
Cable 3: white, black
All the blacks are connected together with a wire nut
Two of the whites are connected with a wire nut.
The other white is from the same cable as one of the reds
Ceiling box for the light
Three cables:
Cable 2: white, black
all whites connected together with a wire nut
all blacks connected together with a wire nut
My question is, how can I decipher what goes where!
Mainly, my problem is that however I think of it there is one cable too many at the light - is it just being used as a junction box to tee off to other points? If that is the case, then I should be able to:
Switch 1: black common, red/white travellers
Switch 2: red common, red/white travellers (pair from the same cable)
Box: red goes to the hot side of the lamp, other side goes in with the whites in the wire nut.
And, last thing, if I am right then the previous owner was wrong -does that mean the three-way dimmer is toast? I've heard they are damaged if wired incorrectly.
Thanks so much for any help!
camelot is offline   Reply With Quote
Old 08-09-2011, 11:15 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Three cables:
Your dimmer is toast. The two 14/2's at the light are a feed in and a feed out. THe black of the 14/3 carries the feed down to the 3way switch and feeds to the other 3way switch via the black of the other 14/3. The red is the switch leg back. Replace the dimmer. Cable #3 at SW2 is a feed out.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
camelot (08-09-2011)
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 11:00 AM
Apartment wiring up to code?? camden2200 Electrical 1 08-03-2009 12:19 AM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
