Making Locks Wirless - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2008, 10:03 AM   #1
Making locks wirless
I just put in a set of digital door locks in my office it has a connection for running a wired remote unlock switch for the secretary I know there is a way that you can make that so you dont have to run wire's for her switch any suggestion .
kenny25271 is offline   Reply With Quote
Old 01-18-2008, 10:41 AM   #2
Rewards Points: 128
Call the company that makes the locks you installed. I am sure there are wireless devices for locks as there are wireless devices for everything else.
If it worked before you worked on it. You did something wrong.
Old 01-19-2008, 12:24 AM   #3
Union Electrician
goose134's Avatar
Agreed. There may be a bit of reconfiguring, but if they make a wireless doorbell, they can do a wireless access system. Maybe.
goose134 is offline   Reply With Quote
Old 01-19-2008, 10:00 AM   #4
Eibwen
We use some Linear products for situations like this. Bascially the same as a single chanel garage door opener.
Reciever would need a power supply near the door area and you'll still need to run cable from the reciever to the door lock via an electrified hinge or a door cord.
Unless its an unusual run, hard wires are a lot cheaper. But I would strongly suggest a cable with an overall shield and avoid flourescent lights when running the cable. They cause a lot of interference.
What make/model do you have?
Sammy is offline   Reply With Quote
Old 01-19-2008, 11:42 PM   #5
thanks bunch i figured it out
ledger locks 108ang General DIY Discussions 2 11-20-2007 01:15 PM
Making a dust collector run with a switch Electricnewbie Electrical 7 07-28-2007 12:20 PM
Locks? mnp13 Building & Construction 4 02-02-2007 10:24 AM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
