#1 |
I ask the impossible!
Making holes in junction boxes
6x6 junction boxes don't come with 2" or 1-1/2" knockouts, so I need to make my own holes. What is the best way to do this, with a strong preference for keeping tooling costs low... I know that a hole saw is one of my inspectors suggestion (the other being a punch) but if I buy a hole saw, I want to be sure that my need for low cost doesn't end up being a waste because I get something where the teeth are gone before the first hole is done.
Multiple smaller holes connected by saber saw is one option I'm considering, but if I can get something that isn't going to cost $30 per hole that will come out cleaner that's the kind of suggestion I'm looking for.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner. |
#2 |
Electrical Contractor
Will you have need for the hole saws after you finish this project?
Invest in a hole saw kit with the needed sizes. A good kit should last you a very long time.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
In a seperate project, I was going to use hole saws to cut the holes in my wood boards from inside the side attic to vent my soffits, but the hole saw I had bought for that lasted 3 holes. It was using a d-shaped hole to drive the saw off the arbor, and the D rounded out.
#4 |
Average Joe/ex-Navy IC3
Punch & Die set will work. What do you mean that you need to make your own holes? If the 6x6 will not work, you will have to move up to a larger box then.
#5 |
6x6 has 3/4" and 1" knockouts. Same with 8x8, it just has more knockouts. 10 x 10 has 1-1/2"knockouts, but no 2" knockouts and no knockouts in the back. Plus it's $48 to the 6x6's $15. Nothing is even getting spliced in any of these boxes, just making a turn so the garage feeder goes to the left and the 3-way switch loop goes up.
#6 |
These work well.
http://www.lowes.com/pd_291471-72068...0051&langId=-1 Little pricey but it should last for quite awhile. These work good as well but not sure if it goes up to the size you need though. http://www.lowes.com/pd_158038-72068...bit&facetInfo= |
#7 |
The preferred method is a KO punch. But they are expensive. I would buy "Lennox" hole saws in the sizes required. Or get a set. When drilling metal, hole saws get super hot. Some oil will assist in saving the teeth. Taking it easy also is a great help.
I had an old electrician show me how to pack some fire stop into the hole saw about half way up. This also helps keep the hole saw cool. I have had one 1-1/8" hole saw for over 20 years and it still cuts. Not like new but it does cut. |
#8 |
Electromagician
the reason a 6x6 box doesn't have 2" knockouts in it is because it is not large enough to have a 2" pipe enter and exit it. for an angle pull like you describe the pipes have to be 6 times the largest size away from each other. I wouldn't gamble on the inspector not knowing that.
#9 |
It's not making any more of a turn than it would be inside an LB pull elbow. If I wasn't needing to have 14 gage THHN go up while the 1/0 XHWN goes to the side, I'd be using an LH fitting.
The old coot is the one that suggested cutting the larger holes in a 6x6 when I asked him for suggestions because the available boxes don't have knockouts larger than 1".
#10 |
Electromagician
I am not on any of the code making panels,(meaning I don't write the code) just informing you that you are planning to violate the NEC. The lb you reference is another place many people go wrong as the 2" lb is not large enough for all wire sizes that 2" conduit is rated for. it is not unheard of to have to use a 3" lb on 2" conduit to pull in larger conductors, legally that is.
#11 | |
Licensed Pro
Making holes in junction boxesQuote:
"Life is hard. Life is harder when you're stupid." John Wayne |
#12 |
1/0 conductor diameter is 0.3249". Section 300.34 defines minimum bending radius for conductors as 8 times the overall diameter for non-shielded conductors. The junction box is 4" deep. So as long as it's less than 1/2" I should be fine. Considering a single 1/0 is can fit inside a 1/2" conduit, I'm pretty sure even if the insulater is included it's under 1/2".
I don't even need the 2" conduit for the underground run, I could've gone smaller and legally met conduit fill, I chose to go larger for my own ease of pulling the wires. Even once I get inside, I'm planning to use 1-1/2" EMT which is larger than the 1-1/4" minimum for the conduit fill requirement. If there's something else I should be aware of, a code citation would be handy for convincing me.
#13 |
Master Electrician
You need to look at the Article on Pull Boxes.
Mark |
#14 | ||
314.28(a) 2 in the last paragraph talks about transposing cable size into raceway size, and since 3 conductors of 1/0 works out to requiring 1-1/4" raceway, 6x 1-1/4" is 7-1/2" so that sounds like I should be okay with the 8x8 box. If something larger than 8x8 is really required, I'll just use an LB fitting, run the THHN in and out of the service panel and from there it will go to the switch, but the inspector didn't want that. If I read anything wrong please explain.
#15 | |
Electromagician
| Display Modes | |
| grounding old 2 wire junction to grounded junction | gm8075 | Electrical | 3 | 03-28-2011 12:46 PM |
| Junction boxes for garage T8 fixtures | mazeroth | Electrical | 13 | 01-25-2010 10:52 PM |
| markers for location of junction boxes under insulation | kelley4180 | Electrical | 14 | 01-24-2010 10:24 PM |
| junction boxes for 4 gauge | bulk88 | Electrical | 10 | 02-03-2009 06:58 PM |
| making holes in the joists to run pipe | christy123 | Plumbing | 5 | 01-20-2007 04:05 PM |
