Old 07-13-2009, 01:27 AM   #1
Making a ground for a surge protector
So I recently lost a TV to a passing lightning storm. It was plugged into a surge protector but it was not properly ground.
I am renting a house that was built in the 20's so it has all 2 prong outlets. Our landlord told us that if we got little 3 prong adapters with a little tab on the bottom and screwed through that tab, it would be grounded. I got a tester and it says that it's an open ground. Actually properly rewiring isn't an option because I don't own the house.
So now I am trying to figure out some way to ground two outlets. I was told attaching the ground to the cold water pipe might be an alright temporary alternative. But when I test the voltage between the ground on the surge protector and the pipe (before wiring them together) there is a 50v difference.
It seems like this could be dangerous because the pipe would now be at 50v. It also seems odd to me that the ground prong on the surge protector is at 50v relative to a pipe in my house.
Thanks,
J
Resilient is offline   Reply With Quote
Old 07-13-2009, 06:50 PM   #2
Licensed electrician
Since you don't own the property the landlord would need to hire someone to properly ground this circuit or to install a new properly grounded circuit.
Grounding to the water pipe is not acceptable.
The 3 prong to 2 prong are useless for your needs and do not provide a ground.
Old 07-13-2009, 07:38 PM   #3
Pound a ground rod into the ground and attach to that.
KHouse75 is offline   Reply With Quote
Old 07-13-2009, 07:42 PM   #4
My License Ain't 4 Sale..
Yeah... That's the way to do it!
Old 07-13-2009, 08:11 PM   #5
It was a dark and stormy
Yoyizit's Avatar
Nah, but if you're worried about it, hook up an incand. lamp between the protector and the pipe. The 50v should drop substantially.
Do these approximate the specs on your protector?
400 v max clamping voltage
600 joules min
1 nS max response time
If you're in FL or the Ozarks in MO you may need more protection.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Is it a hazard to plug a surge protector into an ungrounded GFI outlet? CuriousWithQuestions Electrical 7 02-01-2008 10:04 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
