Old 05-07-2011, 12:56 PM   #1
Making A Ground
I have the old 2 conductor wire with no ground on some of my circuits.
I installed a few GFCI's on some recepticals and now find that an upstairs ceiling light does not work. I may have reversed a hot and neutral but I am not sure as the conductors cannot be identified. So to check my connections, I need to make a ground by connecting a separate single conductor to a cold water pipe, radiator or to a receptical that has a ground so that I can test with my volt meter as to which wires are hot.
I tried to be careful and not mix up the connections but it must have happened. What do you think?
rjordan393 is offline   Reply With Quote
Old 05-07-2011, 01:28 PM   #2
Making A Ground
There is probably a loose connection somewhere, possibly at the last working outlet or light.
A GFCI will work without a ground.
Accidnetaly accidentally exchanging hot and neutral will not prevent a light from working.
You can at any time string a single #14 to #20 conductor from the nearest water pipe across the floor to the place where you are working in order to have a ground for testing purposes only.
Note that a water pipe is not guaranteed to be grounded since there may be plastic pipe between it and the pipes in the basement.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 05-07-2011, 02:00 PM   #3
Mad Scientist
Making A Ground
When I'm troubleshooting older wiring, I like to use a long 3-prong extension cord plugged into a known good grounded receptacle, if one is available. Drag the cord end around with you, and you have a hot, neutral, and ground reference right there for testing.
McSteve is offline   Reply With Quote
Old 05-07-2011, 06:11 PM   #4
Making A Ground
Thanks McSteve,
Very good idea and thanks to AllanJ.
How to connect ground wires? Iva Electrical 3 10-29-2010 01:13 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
