-   -   making an electric go-kart (http://www.diychatroom.com/f18/making-electric-go-kart-166411/)
mark_k 12-13-2012 08:44 PM
Hello, I am looking to make an electric go-kart for my niece. I will be using a 24 DCV motor from a scooter. I am trying to make a list of what all I will need for the electrical controls. I will be using two 12v batteries wired in series. I am planning on then wiring a toggle switch to power it on, followed by a light to tell that it is on. The part that I am not to sure about is my speed controls and also my control for motor direction. I would like to do a pedal type system, or like a boat throttle type, but not sure how to do that. Also to control the direction of the motor, i will need a motor control correct? I'm thinking of using another toggle switch to control the control. Where is a good place to purchase 24 DCV motor controllers. Thank you. Also, sorry for the long post.
chitownken 12-13-2012 08:47 PM
Not sure about what voltage they use, but check out a place that sells or services electric golf carts.
mark_k 12-13-2012 08:51 PM
Hadn't thought of that idea.
frenchelectrican 12-13-2012 10:52 PM
Most golf carts useally wired for 24 or 32/36 volts DC And you will not have issue to find parts and controller with golf carts they do have a few parts you can use.
The last go kart with electric verison what I did is used the forklift drive motour which that is 48 volts and that is pretty wicked. ( I did yank few parts from the forklift and that work pretty well )
Merci,
Marc
mark_k 12-13-2012 11:37 PM
Looked at the wiring diagram for golf carts. They gave me some good ideas but dang, the parts are expensive. May look for a old power wheels jeeps to see if I can slave some of the parts out.
