Makeup Counter Vanity Light Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 01:05 PM   #1
Advertising Photographer
I'm in the process of building a Hair/Makeup counter for my photo studio. I have (4) 36" fixtures set into 3/4" MDF supported by 2x4's that are mounted into the studs , two across the top and one down each side. What is the best way to wire them together if they are not going in the wall and all going to one circuit?
Thanks...
greylockwood is offline   Reply With Quote
Old 02-13-2010, 01:57 PM   #2
Electrician
Rewards Points: 794
if the walls are still open you measure them out and leave a wire sticking out of the wall where the light will be, then when the walls are finished you put the wire into the back of the fixture and screw the fixture on to the wall.
darren is offline   Reply With Quote
Old 02-13-2010, 02:54 PM   #3
The wiring is not going into the walls. It will all be hidden behind the MDF board mounted to 2x4's outside the wall...
Old 02-13-2010, 04:23 PM   #4
IBEW Electrician
mm if your not going to run it in your walls, you could a panduit or pan-way raceway mounted on the surface
Scott3229 is offline   Reply With Quote
Old 02-13-2010, 07:14 PM   #5
Thanks alot!!! I'm gonna give it a go...
Old 02-13-2010, 10:15 PM   #6
Registered User
Termite's Avatar
Don't forget that the vast majority of light fixtures require an electric box to facilitate mounting as well as for containment of the connections.
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Pot Light (CAN) Wiring?? mfleming Electrical 11 03-12-2009 01:01 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
wiring a light Unregistered Electrical 6 01-08-2005 09:19 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 10:59 PM
