-   -   Major electrical trouble shooting in island house (http://www.diychatroom.com/f18/major-electrical-trouble-shooting-island-house-162600/)
PaleoMan 11-08-2012 01:23 PM
First post!:)
I have a house that's about 25 years old on Dog Island, FL. You can only get there by boat, and the island only has a few full time residents. Therefore, getting contractors out there is an expensive endeavor that I prefer to avoid!
On my last visit, I noticed that though all the breakers in the panel were on, the fridge was not working, as well as several other lights. On two occasions, I flipped the light switch on in a room and the bulb immediately blew out. In another room, the lights came on but were dim. The water well pump worked, however, as did the HVAC.
I am an automotive, carpentry, etc., DIYer but have very little experience with electrical projects. Is there an obvious diagnosis for the symptoms I've given?
It is an extremely harsh salt water environment, nothing lasts very long. I would really like to fix this myself if at all possible, and would be willing to completely change out the entire electrical panel, regardless of the cost, if that would fix the problem.
Any initial thoughts?
Thanks in advance!
Jim Port 11-08-2012 01:41 PM
I think you might have lost your neutral. This will cause voltage fluctuations. It may also cause the 120 volt loads not to work at all if it is totally lost. You may want to get the power company involved.
PaleoMan 11-08-2012 07:46 PM
Done! I wouldn't have thought that the problem could be from the meter out, but they seemed agreeable to come get things fixed right away. Hope that does the trick.
Thanks!:thumbsup:
