Maintenance Replacement Of House Receptacles - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 05:19 AM   #16
Originally Posted by handyman78 View Post
As the saying goes, if it ain't broke, don't fix it! Broke as mentioned before meaning loose plugs, cracked, or otherwise worn out.
its already off the list so quit buggin' me scheeschhhh, are you the bride's couzin or what ? ? ?
seriously, do appreciate all the posts ! ! ! of all the forums out ' there ', this seems to attract the best.
yes.itsconcrete is offline   Reply With Quote
Old 11-14-2008, 10:05 AM   #17
-1 for spelling. . .
http://www.google.com/search?hl=en&q...sheesh&aq=f&oq=
Old 11-14-2008, 10:31 AM   #18
sweaty
Rewards Points: 276
Advantages of replacing them:
1. You'll probably see that your original receptacles are back-stabbed and now you can wire them right.
2. You can upgrade to spec-grade receptacles. The extra cost is nothing compared to the cost of labor.
3. You can put 20A receptacles on 20A circuits to get a visual indicator of the higher-capacity circuit.
4. You can put in receptacles that match your current decor better and get rid of ones that had been painted over.
5. When you do a project like this, you understand your own house's wiring better, you may find defects, and you can label your circuits more accurately.
Just be sure the power is off before you change them. Reading Rex Cauldwell's book, Wiring a House, was very informative.
sweaty is offline   Reply With Quote
Old 11-14-2008, 10:43 AM   #19
RippySkippy's Avatar
Had a house built in '73 I bought and occupied it in '95. EVERY accessible outlet was trashed on the inside...not sure what the previous HO did...but there wasn't one that would hold a plug securely.
So should they be replaced? Yes, if they have issues...on an interval...no IMHO.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-14-2008, 01:20 PM   #20
He also wrote books on house inspection and plumbing; definitely, he is a detail person.
Old 11-15-2008, 05:20 AM   #21
yoy'zit, stop bustin' my balls,,, the spelling i chose was not the cuttent prime version but the original version 1st noted in wikipedia v1.0 AND v1.01 house's blt 35yrs ago so no outlet's backstabb'd.
do like the axiom - if it ain't broke, don't fix it - someone post'd.
off to the plumbing forum - follow if you will
Old 11-15-2008, 09:29 AM   #22
I shoulda' known. . .
Old 11-15-2008, 02:55 PM   #23
oy, YOY ! ! !
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
