Main Subpanel Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 06:03 PM   #16
Woah, you sure hes liscensed? Must be fake....
rgsgww is offline   Reply With Quote
Old 11-03-2008, 06:05 PM   #17
Originally Posted by handyman78 View Post
Strongly consider having a professional electrical inspection done before buying that property!
If that is a subpanel those grounds and neutrals need to be on seperate bus bars and the neutral bar needs to be isolated properly. There are other issues as well.
I'd like to know who gave this guy a license...
yes i plan too, believe it or not the wire scheme isnt that bad, most every room is its own circuit with the exception of the 2 small bedrooms, they share a circuit...
yes it is a subpanel well i like to call it that, it actually supplys all the 120 to the house, there is a 6 circuit panel under the meter outside which supplys the 240 to the range, dryer, this panel, etc...
and about his license, he told my kid today that the state of florida only license crazy people, hence the reason he is licensed.. lol
Ratt
rsriverrat is offline   Reply With Quote
Old 11-03-2008, 06:07 PM   #18
Electrician
Ratt
That install needs to be redone, but I've said enough on the subject, i'm otta here.
chris75 is offline   Reply With Quote
Old 11-03-2008, 06:20 PM   #19
Originally Posted by joed View Post
Four wire feed is absolutely required for sub panels. This would not pass inspection. Make sure you list it as a deficiency when you offer on the house.
Also what is that single black wire that is coming out of the same connector as the feed cable. something not right about that either.
All the circuit grounds and neutrals are in the same bus as well. They need to be separated when the four wire feed is installed.
that wire is the wire that runs from the doorbell transformer to the doorbell in the hallway or so it looks like thats what it is..
Ratt
Old 11-03-2008, 06:26 PM   #20
Electrician
Ratt
That is the icing on top of the cake.
Old 11-03-2008, 06:30 PM   #21
ok so now do i become an arse and call the county building dept and see if a permit was required and if so was one pulled, and if not have them come look at it... i dont want alot of drama, and i understand that it doesnt meet todays code, however it has worked for 20yrs with a stabloc with no issues, so other then the code violations, from a safety/burn the house down tonight standpoint, does it look ok for say 1980 standards?
oh and thanks for all the replies, you guys seem great
Ratt
Old 11-03-2008, 07:04 PM   #22
Electrician
Ratt
I really dont know what to tell you. All I know, is that NO licensed electrician did that work, at least one that takes pride in workmanship.
Old 11-03-2008, 07:34 PM   #23
Rewards Points: 2,350
Ratt
I wasn't legal in 1980 codes either. And, by the way, because something has not malfunctioned for 20 years has no bearing on if it malfunctions tonight. Everything that breaks down was working for the entire time prior to break down.
Old 11-03-2008, 08:18 PM   #24
Re-read my posts.
THat install is totally incorrect. An idiot handyman could do better than that. Do you need a permit? I would hope so, but you have un unqualified hack working for a cheap ass landlord. Like I said, get your own electrician in there.
The installation is at the very least; as it was before. Sleep well!
Tankless Man is offline   Reply With Quote
Old 11-03-2008, 09:04 PM   #25
You should see if a permit was pulled, maybe you can get this electrician's liscense taken away so he doesn't have to risk anybody's life anymore (if he actually has one). Depending of your city's code, somebody might get a fine for not pulling a permit. The wiring might have to be torn out, this all depends on your city/state code.
Old 11-03-2008, 09:58 PM   #26
DIYer
Not labeling the circuits is a trivial violation too. Just thought I'd throw that in.
Gigs is offline   Reply With Quote
Old 11-03-2008, 10:38 PM   #27
this is very true, i am going to check into his true licensure tomorrow
yeah i know, i was just trying to get a little reassurance is all
Originally Posted by Tankless Man View Post
Re-read my posts.
i am sure i could have atleast done that, and with load center as inexpensive as they are i could have done it for a hell of a lot less then what they paid him i am sure. i just dont have the liability insurance...
i am gonna check him out tomorrow if i can, as far as i can tell our state/county has adopted the NEC with no modifications for local code situations. permit wise far as i know if you are the homeowner you are allowed to do the work without needing a permit, a permit is only needed if a contractor will be doing the work.
yup, how hard would it have been to label each hot with the amp and circuit as he was disconnecting them.... guess not everyone is anal like me.. if i had done that i probably would have taken all day just to make sure it was all pretty and all...
Ratt
Old 11-03-2008, 11:18 PM   #28
DIYer
On a rental, "homeowner exceptions" often don't apply.
Old 11-03-2008, 11:33 PM   #29
true, i actually meant owner/occupant, in which case this doesnt apply and a permit should have been pulled, oh well i'll find out tomorrow for sure...
thanks again for all you guys help, i'll post back as i find info, just as a fyi. and i'll be posting another thread soon i am sure as i am about to gather supplies for a 60a sub in my newly built shed for a welder and misc woodworking tools.. wonder if i can do better then the nut that did my panel today? i think thats a no brainer.. lol
thanks again all..
Ratt
Old 11-04-2008, 07:41 AM   #30
joed's Avatar
Rewards Points: 13,306
Homeowners usually require permits and inspections as well. They just don't need to be licenced electricians to do the work.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Determining Main Panel Load with Subpanel added Randell Tarin Electrical 2 04-11-2008 01:21 PM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
Subpanel questions wease Electrical 1 12-07-2006 01:39 PM
Add subpanel or upgrade main panel dcoz Electrical 1 01-12-2006 09:24 AM
