Old 08-19-2011, 07:55 AM   #1
Main service panels
Main Panels are they both legal according to NEC.?
1. Main Service Panel 100,200 amps
2. Main Service Panel lug 100, 200 amps
Both with proper circuit breakers .
COLDIRON is offline   Reply With Quote
Old 08-19-2011, 07:59 AM   #2
Main service panels
Not exactly sure what you're looking for here. More info?
CheapCharlie is offline   Reply With Quote
Old 08-19-2011, 08:05 AM   #3
Master Electrician
Main service panels
Because I am both psychic AND I can read your mind I will say, yes.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Code05 (08-19-2011)
Old 08-19-2011, 08:08 AM   #4
A "Handy Husband"
rjniles's Avatar
Main service panels
Used in the correct application, any of the those items would be compliant.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-20-2011, 01:15 PM   #5
Main service panels
More info on the panels
Main service panel looking at it has a main breaker installed up top that says main and turns on and off up and down position.
Main lug panel has busses with lugs and a breaker is added at the top with sideways action.
Old 08-20-2011, 01:15 PM   #6
Main service panels
Originally Posted by rjniles View Post
used in the correct application, any of the those items would be compliant.
thanks
Old 08-20-2011, 01:31 PM   #7
A "Handy Husband"
rjniles's Avatar
Main service panels
This describes a main lug panel with a breaker (back-fed) to provide a disconnect. You do not need a breaker installed in a main lug panel to use it as a service panel. The disconnect breaker can be installed remote from the panel and the feeder connected directly to the panel main lugs. A very common installation scenario.
The Following User Says Thank You to rjniles For This Useful Post:
COLDIRON (08-20-2011)
New service Help (Meter can/ service mast Conduit help) cwolford Electrical 13 03-26-2011 08:55 PM
main service line jocar Plumbing 6 01-19-2011 04:42 PM
Main Lug Panel at Service Entrance mud99 Electrical 16 12-11-2010 06:23 PM
one service main two meters danadude1 Electrical 15 02-28-2010 01:17 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
