Old 02-28-2007, 10:50 PM   #1
Main Service Panel Full
hello,
a friend of mine wants to install an electric clothes dryer, but his main service panel is full. how can he install a sub-panel from the main panel so he can install the dryer? the dryer is 240v, so i assume he will need at least a 30a breaker, and 10-2 romex, with proper plug and outlet.
bob
bobo is offline   Reply With Quote
Old 02-28-2007, 11:00 PM   #2
is it full meaning that there are no more breaker spaces or you are exceeding the amperage rating. if it just doesnt have enough breaker spaces you can get whats called a peanut breaker. they are just smaller breakers that allow you to put more circuits in your panel. when hooking up 240v to peanut breakers you need to make sure you phase it right though. the guy at the hardware store should be able to tell you how to do this. it would be hard to explain the phasing with out showing it to you.
gooch is offline   Reply With Quote
Old 03-01-2007, 06:50 AM   #3
gooch,
i beleive there is no more physical room in the panel. i will find out, and also ask about phasing. thanks!
Old 03-01-2007, 06:53 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Wow, in 25 years I have heard "twin", "tandem", even "skinny"....but never have I heard them called "peanut" breakers. Where did this originate?
Bear in mind, twin breakers CANNOT be used for 240v loads unless they are the double, handle tied, "quad" style.
Old 09-24-2007, 08:09 PM   #5
trust me peanuts is a name for a slim line breaker....that i ain't ever heard
Tony Cunningham is offline   Reply With Quote
Old 09-24-2007, 08:13 PM   #6
Licensed electrician
The correct wire wire be 10-3 + ground, NOT 10-2 + ground.
You would also need to install a 30 amp 4 prong receptacle.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
Arced main lug in service panel burgeke Electrical 4 11-02-2006 12:28 PM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 06:41 AM
