Main Panel Upgrade - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 08:40 AM   #16
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Sounds good. Let us know how it comes out.
John
jrclen is offline   Reply With Quote
Old 08-04-2008, 05:35 PM   #17
Apparently 42 space/slot, does this make sense !!!
Invisible-Man is offline   Reply With Quote
Old 08-04-2008, 07:40 PM   #18
jrclen's Avatar
Rewards Points: 514
It might. Most of the Sq D panels I install in houses are QO 40/40. But I do believe they make a 42/42. They also make a 20/40 and a 30/40. The first number is the actual full size spaces. The second number is the maximum number of circuits using the half size breakers.
John
Old 08-05-2008, 04:45 AM   #19
Thanks John, will let you know how it goes, might not be for a little while.
Old 08-22-2011, 04:20 PM   #20
How do I cover an outside electrical conduit with vinyl siding?
manfredneumann is offline   Reply With Quote
Old 08-22-2011, 04:51 PM   #21
Licensed electrician
Rewards Points: 1,754
It would have been better to start a new thread. As far as covering the mast with siding, the answer is you don't. Unfused conductors before the meter must remain outside the house .
Old 08-23-2011, 03:24 AM   #22
Rewards Points: 338
Jim Port is right. I have seen people run J channel along side the mast and then caulk it though. I've also seen people (not the electricians) paint the mast the same color as the siding to make it less noticeable.
Old thread btw...
petey_c is offline   Reply With Quote
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Add subpanel or upgrade main panel dcoz Electrical 1 01-12-2006 09:24 AM
