Main Panel To Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 06:43 AM   #1
Main Panel to Sub Panel
I am helping a friend wire his house. He has a 40 circuit breaker box and after the HVAC guy puts his 8 breakers in (I still can't believe he needs that many. I only have 3 in my house for HVAC), we will have a full box. The contractor told him to put a 100A breaker and run a wire to a subpanel he needs to mount right next to the main.
If we put another that new breaker in, we will have to move 2 of those circuits to the new subpanel. My question is what are your experiences with subpanels. Do we really need a 100A subpanel and what kind of breaker actually goes in that new subpanel box? Could we just do a 60A?
Any thoughts?
Thanks!
vibbertations is offline   Reply With Quote
Old 08-25-2011, 06:48 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
The load requirment of the subpanel dictates the size of breaker needed to feed it.
Old 08-25-2011, 08:10 AM   #3
Currently, the only two circuits that will be in the box at rough in will be two 15A light circuits but I think there are plans to have a woodshed in a couple years that would need a light and a receptacle.
I am just looking for your thoughts on what you would do.
Old 08-25-2011, 08:29 AM   #4
jbfan's Avatar
Rewards Points: 420
If that is it, then I would go with #6 wire and a 60 amp breaker.
The Following User Says Thank You to jbfan For This Useful Post:
vibbertations (08-25-2011)
Old 08-25-2011, 09:12 AM   #5
6 gauge between the boxes then a 60 amp breaker in both boxes?
Old 08-25-2011, 09:30 AM   #6
Licensed electrician
Rewards Points: 1,502
You don't need a main breaker in the subpanel in an attached structure.
Old 08-25-2011, 11:19 AM   #7
Just call me Andrew
Rewards Points: 1,020
Do a search on subpanels. This topic has been explained MANY times on these boards, you will definitely find lots of good info.
Andrew
secutanudu is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 11:58 AM
gfci in main feeding sub panel problem scott2332 Electrical 12 02-25-2009 11:17 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
