Main Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 03:38 AM   #1
Main panel question
I have a 200 amp main panel located near the meter outside(?). I have a 100 amp sub panel located in the laundry room of my doublewide. I intend to install a tankless water heater, but there is not enough amperage from sub and the main panel is full. Anyone with any advice on how I can set this up? I have an electrician coming to check things out, but I want to be informed ahead of time. The tankless water heater is suggested to have 2 50 amp breakers. Thanks ahead of time.
wyzord is offline   Reply With Quote
Old 08-27-2009, 04:54 AM   #2
Electrical Contractor
kbsparky's Avatar
Your use of the term "doublewide" suggests that you live in a mobile home.
Are the outside boxes (meter box and disconnect) attached to the home, or separately mounted on a pedestal?
You might have to upgrade your inside panel in order to accommodate the increased load.
I do not believe that the Code allows for more than one feeder for a mobile home.
-KB
Old 08-27-2009, 05:08 AM   #3
My main panel and meter are on a pedestal. I am not sure how to do this any suggestions? I would like to have some prior knowledge before an electrician comes so I can understand what he/she may want to do. How much larger of a sub panel can i go to? The one currently is a 100 amp service.
Old 08-27-2009, 05:21 AM   #4
kbsparky's Avatar
You need to upgrade your inside panel to at least 200 Amps, and then replace the feeder wires with appropriate sized ones. Is the outside disconnect box a "feed through" type? Can you upload a picture of your pedestal assembly?
-KB
Old 08-27-2009, 05:32 AM   #5
Pictures are in my album I think.
Old 08-27-2009, 05:50 AM   #6
kbsparky's Avatar
Yeah, that looks like a feed-through panel out there.
It should be suitable for a 200 amp feeder for your mobile home.
-KB
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
Adding a sub panel 250ft away from the main z-man99 Electrical 4 07-19-2009 01:56 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
