Old 08-08-2012, 12:58 PM   #1
Question
main panel minimum height above floor
there doesn't seem to be a minimum height for a main panel above floor, is there?
i was thinking 36" between the floor and the bottom of the panel
Old 08-08-2012, 01:04 PM   #2
Licensed Electrician
k_buz's Avatar
There is no minimum. 36" will be fine.
There. An be no breakers (including main) above 6' 6".
Location...Location...Location
The Following 2 Users Say Thank You to k_buz For This Useful Post:
amakarevic (08-08-2012), Evstarr (08-08-2012)
Old 08-08-2012, 01:14 PM   #3
Licensed electrician
It is actually 6'-7" , not 6'-6" max.
Old 08-08-2012, 01:16 PM   #4
k_buz's Avatar
Fat fingers + iPhone = oops
Old 08-13-2012, 05:44 PM   #5
what do you think if i went only 18" above floor? am i walking on the edge?
Old 08-13-2012, 05:54 PM   #6
E2 Electrician
stickboy1375's Avatar
Im pretty sure a mobile home has a minimum height, but everything else is fair game, I have seen them against the floor.... sucks to work on, but it is, what it is.
The Following User Says Thank You to stickboy1375 For This Useful Post:
amakarevic (08-13-2012)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 09:17 PM
Maxed out main panel and sub panel - additional 240v needed netcustoms Electrical 4 03-12-2011 12:40 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
