Main Panel Breakers, Balanced Loading? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 08:20 PM   #1
Question
Main panel breakers, balanced loading?
I've got a full slate of 30 full size breakers in my 42 circuit QO Square D panel. I want to convert some to tandem breakers so I can add 4 new circuits from a remodeled bathroom. Do I have the same number of amperage/breaker values on each bus?
WoodmanFL is offline   Reply With Quote
Old 11-18-2011, 08:34 PM   #2
joed's Avatar
Rewards Points: 12,376
Not important in a residential setting. The value of the breaker means nothing. It is the load that is connected. So unless you have some permanent heavy loads like heaters that might be running together don't be concerned.
Old 11-18-2011, 08:42 PM   #3
Sfeyelectric's Avatar
You do not have to be concerned with the value of the breakers only the actually load being used.
Sfeyelectric is offline   Reply With Quote
Old 11-19-2011, 11:18 AM   #4
Thanks for the info. That's what I had hoped to hear.
Old 11-19-2011, 04:51 PM   #5
Sparky
Rewards Points: 510
if you have a 42 circuit panel it is almost certainly not allowed to have tandem breakers
Techy is offline   Reply With Quote
Old 11-19-2011, 06:29 PM   #6
Licensed electrician
Rewards Points: 1,474
X2. You are not allowed tandems in that panel.
Old 11-19-2011, 07:06 PM   #7
Why do they make tandems for it then?
Old 11-19-2011, 07:16 PM   #8
joed's Avatar
Breaker panels made by the same manufacturer use common breakers. A 20/40 panel made by the same manufacturer will use the same breakers including tandems.They just happen to fit in the panel you have.
Old 11-19-2011, 07:29 PM   #9
If you only have 30 full size breakers in a panel that will hold 40 there should be no need for tandems.
Old 12-01-2011, 08:55 AM   #10
Been gone for a little while. Attached are some shots of what I've got. Any ideas on how I can add 4 new circuits? If removing a couple full size breakers and adding tandem breakers will work on this panel, let me know.
Old 12-01-2011, 09:21 AM   #11
Licensed Pro
You can run tandems in the bottom 5 spaces (each side) to gain 10 more circuits. You need to move the lower 240V breaker on the left side to maximize the spaces for tandems.
Old 12-06-2011, 04:04 PM   #12
Do the tandems need to go only in the bottom spaces or can I combine some circuits into tandems in the top?
Old 12-06-2011, 04:10 PM   #13
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Only the bottom 5 slots.
Old 12-11-2011, 07:40 PM   #14
Thanks for all the help. Tandems are in and everything is working fine.
Tags
breaker panel , breakers , circuit breakers , main panel , tandem breaker
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
main to sub panel conduit/wire run daddyrabbit Electrical 7 02-12-2010 07:12 PM
Pushmatic Panel, no main, no 2.p. breakers avery2008 Electrical 8 05-02-2009 02:51 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 07:26 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
