Old 03-29-2012, 12:20 AM   #1
main panel
I need to upgrade my main panel. If i have a 100amp main breaker outside can i put a 200amp panel in or do i need to change the 100amp to a 200amp outside?
eternalchild1 is offline   Reply With Quote
Old 03-29-2012, 12:28 AM   #2
DIY Enthusiast
sublime2's Avatar
main panel
I believe you may need to have the wire coming to the house changed to support a 200 amp service.
Call your local power company they will tell you if your current feed can handle the upgrade.
sublime2 is offline   Reply With Quote
Old 03-29-2012, 12:45 AM   #3
Licensed Electrician
k_buz's Avatar
main panel
It would probably be best to post a couple pics of what is existing. Something like what you are proposing most likely will involve more than swapping out breakers.
Location...Location...Location
Old 03-29-2012, 02:05 AM   #4
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
main panel
Just calling power company can sometimes be confusing to a homeowner. They don't always have a good record. Having an electrician personally checking out the service is preferred way. But sometimes a picture will help.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-29-2012, 08:05 AM   #5
Licensed electrician
main panel
Do you just need the 200 for breaker spaces?
Old 03-29-2012, 08:21 AM   #6
rrolleston's Avatar
main panel
Posting pictures of you outdoor panel may be helpful if you have a main disconnect outside you may have more than 100 amps available. to feed a larger panel with more space.
Old 03-29-2012, 08:29 AM   #7
joed's Avatar
main panel
You can install the 200 amp panel. You will still have a 100 amp service however. The 100 amp breaker outside is the one that determines your service size and the cables required.
Do not PM with questions that can be asked in a forum. I will not respond.
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 08:28 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Main panel or sub panel? tbeaulieu Electrical 5 04-07-2010 12:58 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
