Main OFF, Power Still Available In Three Rooms - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 08:02 PM   #16
Electrical Contractor
kbsparky's Avatar
Your photo shows one of the old style QO20M100 panels, with the old-style Q1-top feed breaker.
IF you turn that main breaker off, and there still is power available on one or more of the branch circuits, then the main breaker could be bad.
Replacing the panel is your best option here, since that would be cheaper than finding a replacement Q1-top feed breaker.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
sirsparksalot (09-22-2012)
Old 09-21-2012, 08:04 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,156
Have you tested both incoming hots on the load side,
with the main switch off, to see if it really is completely off !
Could be a faulty switch !
Tell us more about your property ?
House / unit / rural property ?
Any neighbours?, how close ?
Maybe it is sourced unknowingly from elsewhere !
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 09-21-2012, 08:46 PM   #18
Rewards Points: 512
Originally Posted by Jim Port View Post
Sounds like you bought the Homeline panel instead of the QO. The breakers are not interchangeable and you will need new breakers also. If you buy a QO panel you can reuse the breakers.
I'm pretty sure I got the QO, lemme go check the truck.
Old 09-21-2012, 08:50 PM   #19
Rewards Points: 512
http://www.homedepot.com/h_d1/N-5yc1...1#.UF0Y1K4nCXU
Square D by Schneider Electric QO 100 Amp 20-Space 20-Circuit Indoor Main Breaker Load Center with Cover
OH, IC it is a Copper Bus. Is that why you questioned it, Jim? Do QOs generally have a copper bus?
Old 09-21-2012, 08:52 PM   #20
Rewards Points: 512
Argh, bet I gotta get a ground bar kit for it.
Old 09-21-2012, 10:51 PM   #21
Rewards Points: 1,192
You need professional help .
bobelectric is offline   Reply With Quote
Old 09-21-2012, 11:12 PM   #22
kbsparky's Avatar
Yes, they generally do. But some of the smaller panels have aluminum bus, such as the MLO QO612L100
-KB
Old 09-22-2012, 06:32 AM   #23
Rewards Points: 512
Yes, but that's for another thread
Old 09-22-2012, 08:35 AM   #24
Originally Posted by allthumbsdiy View Post
is it still a common practice to have a separate panel for wells?
Nationwide, I have no idea!
Local codes/rules can be different.
Also there is the requirement for an "in sight disconnect" or "lockout/tagout". That is for the safety of persons servicing electrical equipment. So OSHA (worker safety) rules may apply in certain situations too.
Billy_Bob is offline   Reply With Quote
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 02:09 PM
Power in rooms goes on and off by itself. 68 Fastback Electrical 6 10-16-2011 08:31 AM
power to "half" the house dogvila Electrical 8 07-13-2010 09:04 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
