Main OFF, Power Still Available In Three Rooms - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 11:30 AM   #1
Rewards Points: 512
Main OFF, Power Still Available in Three Rooms
Square D 100A. I'm not at the property right now, so I can't check anything with voltmeter.
The circuit working is on breaker 9, and only that particular breaker will cut off the voltage.
I visually inspected the meter outside (it's one of those Smart meters, I think - digital). I didn't notice if the values were changing. I didn't see any other feeders from the meter to another potential panel, and nothing seems to be tapped from the pole.
What's up with this?
Old 09-21-2012, 11:48 AM   #2
Some electrical panels are for rural areas and have a separate breaker for the water well. That is in case of fire, you can still have water with the main breaker off. Maybe something like that?
And I have seen some areas which have a separate electric hot water heater meter - perhaps separate power?
And also is the power really on? Some of those "power testers" will give false readings. Can you plug something in and it works?
And then people do all sorts or weird wiring, no telling what someone did. Take pictures of the panels(s) with the covers off and post here if possible.
Another thing is with office buildings or old homes which have been separated into apartments. They will switch rooms from one unit to the next, but not move the wiring to the other meter. So powered by the meter next door?
Billy_Bob is offline   Reply With Quote
Old 09-21-2012, 12:12 PM   #3
Rewards Points: 512
Thanks, Billy. I'll go take some pics, and post them. This is a single family dwelling in the city.
The power is actually on, as indicated by ceiling fans and lights operating.
Old 09-21-2012, 12:43 PM   #4
Master Electrician
In my neck of the woods they used to have a flat rate 30a service for water tanks. When they stopped the service they didn't disconnect them all. Many places had a seperate 30a service bypassing the meter still fully functional for years.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
sirsparksalot (09-22-2012)
Old 09-21-2012, 02:35 PM   #5
andrew adn billy-
is it still a common practice to have a separate panel for wells?
when you say "bypassing the meter", do you mean there is a separate wire from the street directly attached to this panel?
allthumbsdiy is offline   Reply With Quote
Old 09-21-2012, 02:55 PM   #6
Rewards Points: 1,298
If you can, take a picture of the inside of the panel so we can see what is going on in there. I have seen panels where one "side" of the service was not metered before but not just one or two circuits.
danpik is offline   Reply With Quote
Old 09-21-2012, 04:24 PM   #7
Rewards Points: 512
OK, here's what I've got. I hope they come out large enough to see:
REFRESH BROWSER if first pic appears upside-down.
Old 09-21-2012, 04:42 PM   #8
Well, the plot thickens. I don't see anything on that breaker that would allow it to be hot with the main off.
Need to get a romex clamp on that cable coming in from the bottom. Not sure if my colorblindness is messing with me or is that a red wire going to the neutral?
The Following User Says Thank You to danpik For This Useful Post:
Old 09-21-2012, 04:46 PM   #9
Rewards Points: 512
It's RED, and is being used for the EGC at the bottom: NOTICE, that it's broken off. A real mess.
BTW: If the 1st pic appears upside-down, refresh your browser.
I took voltage tests at each leg, and every other one was OFF (or ON, depending how you care to think of it). So, I'm saying the Main is bad, and replacing the panel is the fix???.
Old 09-21-2012, 04:49 PM   #10
That would make more sense.
I would replace the panel as I hate those panels that have the ground bar surrounded by the incoming feeds.
Old 09-21-2012, 05:00 PM   #11
Rewards Points: 512
Well that first pic won't right-side itself up, so I don't know what to do about it; sorry.
Old 09-21-2012, 05:08 PM   #12
Rewards Points: 512
Well, I went ahead and bought another 100A 20/20 QO panel. This one has an Aluminum Bus, does anyone see a problem with that? If so, I can always take it back before install tomorrow and get a Copper, but I'd rather stick with the price I got, if possible. Is there anything I need to do other than to make sure the breakers are AL/CU rated?
Old 09-21-2012, 05:22 PM   #13
dmxtothemax's Avatar
Rewards Points: 5,368
" With main off "
are you refering to the main breaker/switch ?
Or just one particular breaker ?
Have you confimed its real power ?
not just phantom voltage ?
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 09-21-2012, 05:37 PM   #14
Rewards Points: 512
Originally Posted by dmxtothemax View Post
" With main off "
Main Breaker, yes. The one where the Service enters
Real Voltage 115-118vAC on the live ones
Phantom (around 10-12v) on those dead.
Old 09-21-2012, 07:49 PM   #15
Licensed electrician
Rewards Points: 1,632
Sounds like you bought the Homeline panel instead of the QO. The breakers are not interchangeable and you will need new breakers also. If you buy a QO panel you can reuse the breakers.
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 02:09 PM
Power in rooms goes on and off by itself. 68 Fastback Electrical 6 10-16-2011 08:31 AM
power to "half" the house dogvila Electrical 8 07-13-2010 09:04 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
