Old 01-17-2008, 08:58 PM   #1
main lug vs main breaker for sub panel
I have a duplex with 2 - 100 amp panels mounted adjacently in one basement.
I want to install a sub panel 30 feet away to give tenant access to their own panel.
Original main panels are square-d 1976ish.
I was planning on installing a new 100amp disconnect to replace the main, then use a main lug subpanel 30 feet away.
1. Would the original main breaker be fine as the disconnect? (old 1976). I will be able to drag all the original main panel circuits to the new subpanel, but that will leave all my circuit breaker knockouts open and the main buss exposed.
2. I would like to run the sub feed wire under the joists in conduit rather than drill (old home/butchered joists) What size copper or aluminum wire size do I use? Conduit?
diyll is offline   Reply With Quote
Old 01-17-2008, 09:18 PM   #2
Union Electrician
goose134's Avatar
You can use your existing panel to power your sub, and you can use a main lug panel. You know better than to leave an energized electrical install open, and no one here will tell you different. If you feed the sub panel with conduit, why would you need to leave it open anyway? One suggestion that I will offer is the use of a trough or junction box near the panel. Take the circuits that are feeding the unit and get them into the trough or J box. Run your conduit to the sub to feed the circuits and voila! How much/what size conduit depends on how many circuits and what ampacity those circuits are. Never hurts to leave a spare home run in there either. Keep us posted
goose134 is offline   Reply With Quote
More On This Topic
Let's talk about putting a sign on the breaker box to warn others to avoid others turning our breaker back on. You can say something on your sign similar to what I have. Do not turn circuit breaker number 15 on. Bill is installing a dimmer switch in the... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm here today with expertvillage.com. We just installed a new doorbell in this house and after you have picked up all your tools and make sure you have... Read More »
Hi! My name is Chad Smith and I'm a state certified Journeyman Wireman basically a electrician and I'm representing expertvillage.com. Today we are installing a new doorbell in our house here. The first step that you should take when you are installing... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman. Basically, I'm an electrician. I'm here with expertvillage.com today. The first step that you are going to want to take when you are doing anything with electrical work is you are going to... Read More »
What is Boating Shorepower
What is Boating Shorepower by Expert Village
There are two panels. There's the panel for the battery and the panel for shore power. The twelve volt system, or the battery system, is the one down here. Even while you're plugged into shore power all these items on this panel only run if you have the... Read More »
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Main Breaker panel question stagger19 Electrical 5 08-15-2006 04:57 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
